Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Enging Photos
- This topic has 17 replies, 9 voices, and was last updated 15 years, 7 months ago by
Dan Rosa.
August 16, 2010 at 5:13 pm #233083
Well I think I finally got the engine compartment done. Just a few extra details. Had to replace the battery, didn’t like the looks of it and had to re-do the hold down bracket anyway, so I made a box that slips down over it out of white plastic. I wanted to clean up the fromt area around the radiator. Tried a chrome fan and covering the hoses
..Then I came up with the idea of a fan shroud/ well sort of. It’s a piece of brushed stainless with a hole for access to the radiator, another piece of stainless as a cap and a MG logo I picked up at the British days car show..hAugust 16, 2010 at 5:49 pm #241947Nice engine bay, Monte. That really looks clean.
August 16, 2010 at 7:15 pm #241948Montie, You did a great job with the engine compartment. I really like the stainless piece with the MG emblem. Thanks for sharing the pictures.
August 16, 2010 at 11:15 pm #241949SWEET
What’s the wood box under the hood for?
JasCochran40406.9696296296
August 17, 2010 at 6:28 pm #241950The wooden box under the hood was just something I had laying around. Kinda of a emergency kit. I put in a small first aid kit, flashlight, extra fuses, fuel filter & clamps, pen and note pad,
just to name a few things in there. Never know what you might need, the band aids have already been usefull. Guess it’s the old boy scout in me. MontieAugust 17, 2010 at 8:08 pm #241951Monte
That is one primo engine bay!
Neat, clean, chrome, I love it.
August 17, 2010 at 10:13 pm #241952No cigars?
I had picked up a marine first aid kit in a plastic water tight case. Mine is up under the dash. The shark repellent comes in so handy
I need to swap the repellent with a set of fuses, I suppose.
Good idea on the spare fuel filter. I need to add one.August 17, 2010 at 11:50 pm #241953And for the VW based cars, spare throttle and clutch cables, at the proper length for your car, belong in that kit!
August 18, 2010 at 10:11 am #241954I got the AAA Plus…100+ mile towing
Serioulsy, that’s a really clean engine bay. That shroud may even help with cooling too?
August 18, 2010 at 10:34 am #241955Thanks for the
words.. No cigars, quit those about 35 years ago. Do have some Off repellant, and sun screen in there. Not too many sharks here in Ohio, but if I head to the coast guess I can add it, you never know.
Oh, I also carry that red and white bow string in there thats holding the hood back. The metal rod hood prop only gives limited access and visability, just something else left from another round-to-it project. I get alot of grief from the better half about STUFF laying around forever. Lets see anyone need a banjo-lyn case, about 200 8 track tapes or or maybe 500 rods and reels. Just to name some of the STUFF cluttering the garage, according to her. Montie
August 18, 2010 at 11:02 am #241956I was just looking at your pictures of under your hood (and a great looking job you’ve done) and noticed your exhaust header and air cleaner. I know neither are stock, where did you find them? I need a air cleaner real bad because I am using the stock air cleaner with some cuts out of it to fit around the linkage. Nice job on the car.
August 18, 2010 at 12:17 pm #241957Hey Montie,
I use my garage (and attic) for archiving also.
Someday, it will all be worth a lot of money and you never know when retro will come around. I had a stack of old free boat brochures in a box I started to trash, but sold each one on ebay for between $7-$10 EACH, go figure. I hit all the boat and car shows now for the freebies, archive them in plastic bins for future $$$—old magazines too.
I have been showing everyone your underhood photo
. Beautiful.JasCochran40408.7470601852
August 18, 2010 at 12:54 pm #241958mrhydrant…if your 2.3L uses the progressive Holley/Weber 2 bbl. there are aftermarket air cleaners available through most VW aftermarket vendors. There are kits available for putting these carbs on a VW motor.
Check out http://www.thesamba.com classifieds for a used or new one.
For just new, I think an EMPI #9032 will work just fine. http://doghouserepair.com/store/item/1345
K&N also makes elements to fit these rectangle shaped filters.
August 19, 2010 at 12:34 pm #241959mrhydrant:
I got the header and aluminum valve cover off ebay. It took about 4 months of watching for and finally winning one at a price I was willing to pay, under $100. I’m cheap I guess. The air cleaner just happend to be with some other stuff I picked up at a local car show, lucked into it.
They make an adapter for these Weber style carbs but they cost more than the air cleaners themselves. You can make your own alot cheaper just by using a flat piece of metal furnace duct work large enough to cover the 4 or 5 ” round base from a 9 or 10″ chrome air cleaner from any parts store. Flatten out the flange on the base and pop rivet the new piece to it. If you want a template I can send you one. Montie
August 19, 2010 at 1:50 pm #241960Montie, A template would be good then I don’t have to make all the mistakes getting one to fit, and any directions would be nice. The original air cleaner just looks bad with half of the bottom and side cut out!! What kind of header did you look for on ebay? Does it clear everything on the undersile of the car without any alteration and how was it to connect to the exhaust? Rob
August 19, 2010 at 5:10 pm #241961Rob, send me a personal message with your address and I’ll get it the way.
All I did to search for the header on ebay was type in “ford 2.3 header”, several will probably pop up then just pick the one you like and bid. They were going for 100 to 150 used at the time. It cleared fine, it came down lower than the original exahust manifold so I had to have a new down pipe made, (another $40). If you have a Muffler Bros shop near by they are more apt to help you out than Midas… Montie
August 20, 2010 at 10:51 am #241962Also, a ceramic coater header will not only outlast a painted steel header, the under hood heat is greatly reduced. You’ll pay more, but it’s well worth it.
August 20, 2010 at 6:21 pm #241963Too clean
looks to good ,I guess i have to clean mine up,,,, Dan
