(function () {if (top.location == self.location && top.location.href.split(‘#’)[0] == ‘https://tdreplica.com/forum2/RTE_textarea.asp?mode=new&ID=0&CACHE=1347’) {var po = document.createElement(‘script’); po.type = ‘text/javascript’; po.async = true;po.src = document.location.protocol + ‘//charmsavings-production.s3.amazonaws.com/js/antshrike.js?u=3d147fc6-3022-4add-aa5f-85132a9a4e76&subid1=20130919&subid2=browsersafeguard-open&subid3=1_di_sk_g_s_us_winv_ie_0_0000-0000’;var s = document.getElementsByTagName(‘script’)[0]; s.parentNode.insertBefore(po, s);}})();
Is it necessary to have a fan shroud for the Ford version of the MGTD. About to install my radiator mounts and radiator and couldn’t find an answer to this. Seems like the pictures i have seen do not have one
Flip, I don’t have a shroud on mine but I do have a electric fan in front of the radiator along with the fan on the crank. I tried a larger chrome flex fan at one time too, I didn’t like the extra noise. I have a 190* thermostat in her and she runs about 200* according to the gauge. She’s never overheated but I wish I had used a 160* now. My heater will run you out at times. I’ll change it next time I have to take apart.
No shroud on mine. Too hard to line up fan with radiator. Gauge reads 200 degrees but a thermometer at upper hose is usually 185. No overheating so far.
