Home › Forums › MGTD Kit Cars › VW Based Kits › Fender welt replacement(piping)
- This topic has 3 replies, 3 voices, and was last updated 17 years, 10 months ago by
October 29, 2008 at 9:15 am #232458
I have a Fiberfab kit that is in bad condition…I found a chrome grill shell(Thank’s Pat) but now I have to replace all the fenders welt(piping) all around the car…Up to date I have removed the rear fenders and back trunk…but I have problems taking off the front fenders and the running board…do I have to lift the body from the VW platform ???Hope not !!!!!! If I have to do that…any suggestion how to proceed….if I have to do it …maybe I should also replace the floors (both side) that are also in bad condition…This is the problem bying a car on internet…..without having seen the car…and trust a guy that send you pictures of the car that were taken ….10 or 15 years ago…..YES I WAS STUPID(paid in full before having the car)..and now I have to bring that car in good condition…Thanks
Andre
October 29, 2008 at 10:14 am #237667You shouldn’t have to remove the main body from the floor pan. These VW based CMC/Fiberfab kits had a “false” firewall, usually made of wood, accessible from inside the car. If you can remove that, you will probably be able to get at the rest of the bolts.
Good idea to replace the floor pans…you’re sitting on them.
Bummer that the seller was not “up-front”. Buying a used “regular” car is risky enough, now you know that buying 25 year old kits cars sight unseen is a no-no. As long as you have the cash, skills and time, you’ll get it corrected.
October 29, 2008 at 12:22 pm #237668Thanks for your help…Pink MG…
But can I replace the floor pan without lifting the body from the platform ???
Andre
October 29, 2008 at 12:59 pm #237669Andre,
You might be able to cut out the damaged portions and weld or rivet in patch panels.
But if you need to do complete replacements of both sides of the pan, you are going to have to lift the body. The main body panels bolt to the original body mounting holes for the Beetle, which run along the outer channel of the floor pan.
My personal build experience is with Classic Roadsters Duchess, but I think all of the replica bodies attache pretty much the same way.
PMOSSBERG39750.5421990741
