Floor Pan Rust Preventer
Home Forums General Discussion Floor Pan Rust Preventer
  • #233622
    Mark Konrad
    @mark-k
    Hi Guys
    Hey has anyone used POR-15 on their VW floor pans or any other parts to take care of miner rust and prevent future rust?
    #245918
    newkitman
    @newkitman
    Mark,
    I completed a body off resto on my 74 Ghia and used POR-15 on the entire chassis, to include new floor pans, front beam, etc., the wheel wells, the underside of the engine bay, and inside the door panels. Stuff works great. Two cautions. One…when you apply the POR-15, make certain you don’t get the POR-15 on any bolt threads or studs because you won’t get the nuts to fit and it is almost impossible to get off. Two…cover yourself really well because that stuff is even hard to get off your skin.
    I’m going to use POR-15 for my TD chassis. And run some Marine Clean through the fuel tube to make certain all the varnish from old fuel is gone and the fuel line is squeeky clean.
    #245919
    Mark Konrad
    @mark-k
      Thanks Allen for the info.  From what I had read its great.  The TD  I just purchase has some very minner rust and wanted to stop it there and prevent any furture rust before I r-ecarpet etc. and finish the restore.
