Home › Forums › Site › Rules and Etiquette › Forum Software Updated
- This topic has 10 replies, 4 voices, and was last updated 12 years, 1 month ago by
February 6, 2014 at 6:29 pm #235084
I’ve updated the forum software to the latest release.
Update Sever Response You are currently running the latest stable release.
Edition: Premium Edition (with Web Wiz Branding)
Running Version: 10.17
Database Backend: SQLServerLastest Version: 10.17
Release Date: 1st November 2013
Release Notes: Added support for IE 11 and Windows 8.1.Please let me know if anyone else see any of the reported issue you were having.February 6, 2014 at 7:09 pm #259567Thanks Frankie!
Slowly coming back from the ashes...February 6, 2014 at 7:12 pm #259568FYI: The Reply above generated this error in Chrome Version 32.0.1700.107 m:
Microsoft OLE DB Provider for SQL Server error ‘80040e2f’
Cannot insert the value NULL into column ‘Forum_ID’, table ‘devinew_forum.dbo.tblEmailNotify’; column does not allow nulls. INSERT fails.
/forum2/new_post.asp, line 1404
Slowly coming back from the ashes...February 6, 2014 at 7:14 pm #259569I’m on Chrome Version 32.0.1700.107 m
Testing…February 6, 2014 at 7:16 pm #259570I did not get the error with my Reply. Second test with Email Notify me with Replies check…
February 6, 2014 at 7:16 pm #259571same message here..
February 6, 2014 at 7:19 pm #259572Ok… below the reply box are two check boxes.
Enable BBcodeEmail Notify me of RepliesPlease make sure the Email Notify me of Replies is unchecked until I figure out the issue with the Database.EDIT to add:You may need to change it in your profile in the Member Control Panel. If you have it set to YES in your profile, every time you post, the email option is set.FrankieD2014-02-06 19:21:51
February 6, 2014 at 7:22 pm #259573This is a test with IE 11.0.2 and Email Notify unchecked…
EDIT:
It did not generate an error message… 🙂
KentT2014-02-06 19:23:01
Slowly coming back from the ashes...February 6, 2014 at 7:24 pm #259574KentT wrote:This is a test with IE 11.0.2 and Email Notify unchecked…
EDIT:
Good to know I’ve narrowed down the root cause… Finding the fix may not be so easy. I will keep everyone posted…February 6, 2014 at 7:39 pm #259575BTW, folks…
You can go to Member Control Panel > Forum Preferences and there is an option called: Notify me of replies to posts
If you specify NO on that option, the Email Notify Me of Replies checkbox on these forms will not be automatically checked….
That way, you won’t have to remember to uncheck it every time to avoid getting the error message…
KentT2014-02-06 19:39:45
Slowly coming back from the ashes...February 6, 2014 at 11:16 pm #259576Thanks Frank.
Nice to know you are still watching over us.
