Home › Forums › MGTD Kit Cars › VW Based Kits › Front Shock Question
- This topic has 10 replies, 5 voices, and was last updated 13 years, 3 months ago by
June 2, 2012 at 3:47 pm #234167June 2, 2012 at 8:34 pm #250750
Allen,
I don’t have my car in front of me, but I don’t recall any “adapters”.
Stock front end, stock shocks, stock bolts.Paul Mossberg
June 2, 2012 at 8:59 pm #250751Allen, I’m a ’69 but don’t have anything like that. All stock here too.
June 3, 2012 at 11:24 am #250752My 71 Chassis doesn’t have any shocks front or rear and there are different styles listed in the VW parts houses and wasn’t sure which I needed. I’ll order stoch front and rear. Thanks guys.
"If one thing matters, everything matters" - from the book The ShackJune 3, 2012 at 12:41 pm #250753Allen , dont have them on my 74. I used a cheap oil filled shock.I bought them from JC Whitney a few years back. They work fine. This was before I learned there are much better places to get Beetle parts than Whitney.
Mike N Scarlett2012-06-03 12:43:46June 3, 2012 at 5:19 pm #250754I’ll order mine from Mid America Motorworks. Better price including shipping that locally.
"If one thing matters, everything matters" - from the book The ShackNovember 17, 2012 at 9:53 pm #250755During the FL Bug Jam it came to my attention that I installed my front shocks incorrectly. So…when I disassembled the top setup and installed the shocks and rubber spacers correctly my shocks don’t extend any more (they are at full travel) and I cannot get the top nut on. The threads of the shocks don’t protrude through the arm on the front beam. I have two new Monroe front shocks from NAPA. So my question is do I order two new shocks from a VW parts house or order the extenders for a 66-74 beetle shown below?
"If one thing matters, everything matters" - from the book The ShackNovember 26, 2012 at 7:21 am #250756Problem fixed. And didn’t need the extenders.
"If one thing matters, everything matters" - from the book The ShackNovember 26, 2012 at 7:49 am #250757How did you do it?
November 26, 2012 at 10:30 am #250758Had no weight on the front end to push the shock up into the arm on the front beam. Used a jack to lift the lower trailing arm and got everything lined up and torqued. Did that for both sides. I probably should have waited until I installed the body and had tires on. Live and learn.
"If one thing matters, everything matters" - from the book The ShackNovember 26, 2012 at 10:47 am #250759Ah! “No weight” on the front is the usual situation with these babies. Every little bit helps.
