Home › Forums › General Discussion › gauges gauges gauges
- This topic has 4 replies, 5 voices, and was last updated 16 years, 12 months ago by
Brian Key.
July 16, 2009 at 11:58 am #232682
Hello all. another MGTD kitcar owner here.
Cant seem to find gauges. or should I say as soon as I say aircooled VW nobody seems to know what to do… mainly because of senders.
I would like to put some classic looking gauges like vdo heritage or autometer oldies.
anyone done this?
July 16, 2009 at 3:56 pm #239307VDO sending units at:
http://www2.cip1.com/SearchResults.asp?Cat=1763
If you already have a source for VDO Heritage, the sending units above should work with them.
July 16, 2009 at 4:01 pm #239308Hi, I went to http://www.egauges.com and went with the VDO Cockpit Royal group as that group had a oil temperature gauge. I e-mailed the co. and told them what kit car on what doner car I had and they responded with the sender numbers to match the chosen gauges. I have a speedometer, tach, volt, fuel, and oil temp gauges on the way. Haven’t seen them yet as I am not home this week. I wanted a clock also and went with the Autometer Old Tyme white. I wanted a 90-95 mph speedometer, but none was available in the style and size I wanted. The speedometer and tach I bought are 3 1/8″ dia. as the holes in the dash are 3″, and I didn’t want the hassle of opening them up to 3 3/8″ or 5″. Hope this helps, Rollie
July 20, 2009 at 10:08 am #239309http://www.classicinstruments.com/
Real TD’s had large (5″ ?) diameter Speedo & Tach too. Not the 3.5″ diameter we usually see in our replica’s.
You really only need a Speedo & TACH both (large diameter), Fuel, Oil Pressure and Volts. The head temp senders are usually a spark plug washer style sensor.
August 5, 2009 at 9:51 pm #239310I believe that it is still possible to get Smiths gauges rom the UK. Not sure about cost but they do look cool.Classic instruments as recomended above are realy nice to. i looking at changing mine to so that they look more like the originals.
