Home › Forums › MGTD Kit Cars › VW Based Kits › grill fitting
- This topic has 7 replies, 6 voices, and was last updated 13 years, 10 months ago by
craig.
April 29, 2012 at 5:03 pm #234119
I purchased a fiberfab mg that was never assembled. Some work to the fiberglass was started, trimming and holes drilled. Anyway, I’m at the front fender, hood, side panel install point, trying to fit the grill assy, the grill assy is 1 inch wider than the front edge of the hood. Has anybody encountered this situation before and whats the fix?
Thanks CraigApril 29, 2012 at 5:27 pm #250327Wow Craig,
The obvious comment is that they should match up. I know, “duh”.
The FiberFab assembly manual assumes some trimming will be needed at the front of the hood, but nothing this drastic. But let’s start there.
You’re sure the rest of the body is aligned correctly? And the rear portion of the hood is fitting properly to the front of the cowl? I’m hopeful, but not confident, that your hood is simply too long. Trimming from the front would result in a broader opening at the front of the hood.
If all of the above is correct, I’m at a loss.
You might have parts from different kits, even different manufacturers.
April 30, 2012 at 10:43 am #250328Is there a magic number (length) that the hood should be? If you shorted the hood that means that the side panels will have to be shorten too. Now witch end (front, back, split the diff.) do you take the excess off? Plus both side panels should be the same length, right? Doing all this and making sure the hood assembly still fits in the fenders (no adjusting to these). It sure would have been a lot easier if in the assembly instructions some numbers would have been added, then trial and error wouldn’t have to be used.:?
April 30, 2012 at 11:19 am #250329Craig,
I have a old Fiberfab MG TD – I restored it a few years back and just put it all back together so never was in your position. I can however measure mine ( side panels etc. ) and take pictures and email them if that will help. Email me off line if you want to take me up on the offer.dlschu42 at comcat.net Substitute @ for the atDaleApril 30, 2012 at 11:21 am #250330Everything Rob writes is accurate, but I was not sugggesting any of that would need to be done.
Like I wrote, my “hope” was that the hood was simply too long because the manufacturer did not trim it accurately.If that is not the case, I really can’t explain the mis-fit.Paul Mossberg
April 30, 2012 at 11:44 am #250331Craig, I measured the hoods on my BCW [Chevette based] and my London Roadster [VW based ] cars and while the BCW is 3 and 1/2 ” longer, both are the same width where they meet the grille.It seems that the diminsions vary with the different manfacturers. I did notice on the LR ,that I have to pull slightly on the side of the hood spreading it slightly as I close it to allow it to fit over the grille. Is it possible that your hood has been stored with the sides squeezed and if so ,could the be heated and spread out slightly VERY CAREFULLY ? Could the flanges on the grille be bent in to narrow the grille enough? All the above is assuming that the side panels and the hood match in length and fit the rest of the car correctly.
May 2, 2012 at 1:07 pm #250332When I first assembled mine, I followed the instruction book.
As hard as I tried, I could not mahe the grill, side panels, hoodline up in any acceptable manner. Frustrated, I called the factory(Still in business at that time) and was informed that I should notfollow the manual. I was told to start the assembly at the back end.I thought he was crazy. What difference would it make?I took his advise, though, and by the time I got around to the front endagain, everything lined up. Go figure.Just a note from my experience.Bill Ascheman
"Drive Happy"May 4, 2012 at 12:20 pm #250333My weekend is finally here and had chance to get back to the car this morning. I measured back from the front edge of the hood to get to the point the hood will fit the grill, approx 1.5 in., I can shorten the side panel 3/4 inch each end. The hood fits well at the cowl as do the side panels. Before I do any cutting I plan on clamping the rear fenders and running boards in place to check front fender fit!
Building a kit car is something I always wanted to do, Ive restored several cars in the past,all british so not much intimidates me,I’ll get through this and want thank everybody for their responses and ideas
Thanks Craig -
