Home › Forums › MGTD Kit Cars › VW Based Kits › hand brake
- This topic has 3 replies, 2 voices, and was last updated 18 years, 4 months ago by
October 25, 2007 at 11:40 pm #232335
I’ve got a Daytona MIGI that I’m replacing the hand brake handle on. It hasn’t been functional since I’e had it. Any tips on how to mount the assembly so it will work? Obviously it doesn’t work in the normal position. Any info will be appriciated.
October 29, 2007 at 11:56 am #237203My Duchess has the hand brake in the stock position. It’s a long reach under the dash, but it works. I’ve seen some that cut the brackets, bent the mounting plates up and welded in supports so that the handle was easier to reach. Not sure what manufacturer recommended that, but it seems to funciton well.
You wrote that it has not been functional since you bought your car. that does not sound like it’s because of the mounting. Is the cable broken? Frozen into the cable housing?
PMOSSBERG39384.4976967593
October 29, 2007 at 10:43 pm #237204In the stock position the handle hits part of the firewall that juts back toward the back of the car. Doesn’t have enough travel to engage the brake. When I got the car the handle was in an upright position so you could engage the brake but the mechanism that locks it wouldn’t work. I guess I could modify the firewall but it seems like daytona would have had some way to make it work without doing that.
October 30, 2007 at 9:30 am #237205I agree Daytona must have had a way to work around this. I don’t have personal experience with that manufacturer’s car. But the mod I described earlier should have brought the ratcheting mechanism up with the rest of the handle. Hopefully some Daytona owners are reading this!
- The topic ‘hand brake’ is closed to new replies.
