Home › Forums › General Discussion › How much does my TDr weigh
- This topic has 19 replies, 8 voices, and was last updated 11 years, 8 months ago by
Dale Schumacher.
June 14, 2014 at 8:16 am #235221
How much does it weigh and how is it distributed?
For many years, I have weighed my cars using a standard bathroom spring scale. (I grew up in the country.) (Don’t worry, you won’t break the scale.)All you need is a good 6 ft long 2×6 (or 2×8), a scale (the digital ones don’t work as well), and a couple pieces of angle iron (or heavy stock aluminum).On the board, measure and mark a line 6 inches from an end. Then, from that mark mark new lines every foot down the board. Now you have marks at 6 inches, 18 inches, 30 inches, etc to the other end of the board.Jack up a wheel of your TDr, and place the board under the wheel with the center of the tire at the 18″ mark. Put a 6-12″ piece of angle iron under the board at the 6″ line that you drew. The angle iron should be upside down (pointy end up) on your concrete drive (make sure your drive is approximately level).At the 4 ft mark (actually 4 ft + 6 inches from the inside end of the board), and under the board, put the scale with another piece of angle iron on the scale (pointy end up) directly under the 4ft mark.The scale reading should be recorded (reading A). Then slowly let the Jack down. Note the reading on the scale (reading B). Subtract A from B and multiply the result by 4. The answer is the weight of your car on that wheel.Continue for the other 3 wheels and you’ll have the weight on each wheel. Add all 4 and this is the total weight of your TDr.Note this method is approximate and how accurate depends upon the accuracy of the scale and how accurately you measured your marks and placed your tires and angle iron. Regardless, you now have a better idea of what your TDr weighs. And how it is distributed.June 14, 2014 at 8:39 am #260599So… how much?
June 14, 2014 at 12:38 pm #260600Planning to drive Bridget to the dump as soon as she’s drivable.
June 14, 2014 at 12:47 pm #260601that works too
June 14, 2014 at 1:21 pm #260602Ed… to leave her??? Say it isn’t so.
June 14, 2014 at 1:59 pm #260603Ha! Just to weigh her, I hope.
I did say “when she’s drivable” after all.June 14, 2014 at 6:30 pm #260604We midwesterners would use the local grain elevator scale. 🙂
June 14, 2014 at 6:42 pm #260605You guys are all spoiled. There wasn’t a scale at the dump or a grain elevator or a DOT big rig weigh station within an hour’s drive of my house.
June 14, 2014 at 8:19 pm #260606I like your method, Roy, since you get the weight over each wheel, which can be interesting and even important.
June 14, 2014 at 10:57 pm #260607When I went to DMV the first time to register it. The DMV dude ask how much does it weigh. He said I would need a computer print out of its weight Took it to a local gravel pit. The scale guy was into the car so there was no charge . 1,846 lbs
June 15, 2014 at 8:17 am #260608Greg
good to know since I have a LR too thanksJune 15, 2014 at 2:51 pm #260609greg, is that with you in it, or not?
June 16, 2014 at 9:42 pm #260610This sounds like a loaded question . I wasn’t n the car . When I was at Carlisle I noticed most of the members seemed to be big or tall. I have dropped about 30 lbs. My wife says I was afraid I wouldn’t fit in the car . Little does she know I did it for her. I was at a show and a guy watched me get out of the car . He was my size . He said you just answered my question . I’ve wanted one of these but I wasn’t sure I would fit . I told him it wasn’t the real deal . Just wondering are we bigger or smaller than the other ones
June 17, 2014 at 7:27 am #260611Greg, I wasn’t trying to load you!
Just wanted to get the figure right. The 200 lbs (more or less) difference with the driver seated in the car works out to more than 10 percent of the total weight.BTW, I think one of the biggest selling points for the replicas–especially the VW variant–is how much roomier they are than the original. For a normal, modern American man, it really can be the difference between fitting and not fitting.FYI, BCW marketing stuff claims their car weighs 1575 pounds all done. That always seemed optimistic to me, but I never yet weighed her to check. Stay tuned.edsnova2014-06-17 07:27:37
June 17, 2014 at 9:37 am #260612Hey Greg…I’m 6’2″, and about 220 and have no problem in my Classic Roadsters VW based Duchess.
In fact, once the car was done, I realized I moved the pedal cluster too far back, further than the assembly manual recommended. I could have had even more driver leg room had I trusted the assembly manual!Paul Mossberg
July 9, 2014 at 11:30 am #260613Finally found time to weigh MiGi. I used the method I described above in the first post. Using a balance beam type bathroom scale rated @ 350#.
My car is a Daytona MIGI. VW. 1/2 tank fuel. Spare tire under the bonnet. Battery under passenger seat. 20# worth of tools up front behind radiator. Top, curtains, boot and full tonneau in car. No weights or sand up front. No driver or passenger.Front: 732#Rear: 1256#Total: 1988#Distributed: 36.8%/63.2% (front/rear)Royal2014-07-09 11:49:18
July 9, 2014 at 11:50 am #260614Royal,
Were you in the car when it was weighed?BDriverJuly 9, 2014 at 3:14 pm #260615Let’s see… “No Driver or Passenger” I would say the answer is no.
But then, I was mistaken once before.:Pmustang_evets2014-07-09 15:16:54
July 20, 2014 at 6:09 pm #260616Well, I re-weighed after determining that somehow the zero had gotten knocked off by 6#.
My new super accurate measurement (without the spare) is:Front: 675Rear: 1232Total: 1907 (+/- 2 oz)July 20, 2014 at 6:15 pm #260617Roy
I never would have guessed that much being that the steel framed speedsters are only slightly more in weight. -
