Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Location of fuel pump and horn relays
- This topic has 8 replies, 6 voices, and was last updated 11 years, 6 months ago by
billnparts.
September 23, 2014 at 7:54 pm #235399
Just finishing up installing the wiring harness in my Ford MGTD and am trying to determine the best place to locate the fuel pump and horn relays. Electric fuel pump is mounted near the gas tank in the rear. Thinking that on the firewall near the voltage regulator and ignition module makes most sense but that requires more holes in the firewall. Any ideas would be appreciated.
September 23, 2014 at 8:14 pm #261580I do not run a fuel pump relay on mine. I only added a horn relay recently. Probably didn’t need it. I found the intermittent operation was a ground short in the switch in the wheel. I put that relay behind the grille above the horns.
"Drive Happy"September 23, 2014 at 10:35 pm #261581If I were smart and neat I would put all the relays in a pod on the firewall or maybe inside the tub, up under the dash. But accessible.
Because I am not smart or neat I now have relays all over the dang place–inside the right front cowl (three light relays); left cowl (horns); sitting unsecured next to the battery (fan) and under the driver’s seat (fuel pump).My advice, in all things, is don’t be like me.September 23, 2014 at 11:15 pm #261582I put my relays along the fire wall above my fuses.
September 24, 2014 at 7:49 am #261583Nobody beats the Wiz.
September 25, 2014 at 5:28 pm #261584Thanks for the comments. I think I will put them under the dash in a easy place to service. Do you use relays for the headlights? Plans I have don’t suggest one is needed.
September 25, 2014 at 5:58 pm #261585I currently have my relays just hanging behind the dash. I do use a relay for headlights and it does help with the brightness.
And where do you get those relay receiver plugs? I’d love to get a few of those and clean up some of the wiring mess behind the dash.September 25, 2014 at 6:07 pm #261586September 25, 2014 at 6:41 pm #261587The Ford headlamp switch has it built in.
"Drive Happy" -
