Home › Forums › General Discussion › London Roadster Gets a Lift
- This topic has 37 replies, 8 voices, and was last updated 10 years, 11 months ago by
john barry.
February 10, 2015 at 8:00 pm #235572
well folks,
my new to me roadster will be going up on my lift, tomorrow evening, after dinner.
hope to get some good pictures underneath, and, see just what all needs fixing.
finally got my B to the point of being back on the floor.
plan to drive it some, soon, now that the cooling system is back in correct order.
February 10, 2015 at 9:12 pm #263116Good on ya. I’d love to see some beauty shots of the hot rod B
February 11, 2015 at 6:19 am #263117workin on that.
still have to put the console, and stereo back in, but, that’s inside stuff, and, hope to get that in this evening, too.
I was happy just to get it off the lift. been sitting there for 2 months.
February 11, 2015 at 7:36 pm #263118well,
it took a little doing, but, I finally got it up on the lift, and, immediately found all the allen bolts in both axles loose, so, I tightened those back up, and, hooked the heater tubes back up.
had some company to stop in, so, the pictures will have to come tomorrow.
lots to do under there.
February 11, 2015 at 8:08 pm #263119I find that when company arrives thats the time to pass the tools around for free help. Remember Huck Fin and the white wash paint? Who doesnt want a chance to spend some time with an exotic car? Pass out beer with the tools and call it a party!
February 11, 2015 at 8:21 pm #263120he drove over, and, I wouldn’t want to get anyone in trouble, especially on a week night.
I’m trying to keep my week night sessions to 1 to 1 1/2 hours, so, time was running short, when he stopped by. we just kinda poked around under it a little, then went over to his car, and, poked around a little more.
might be a bit more serious tinkering going on this weekend.
February 11, 2015 at 8:30 pm #263121if
you get the front and rear shock absorbers model #s let me know pleasethanksFebruary 11, 2015 at 8:53 pm #263122Great plan! I started out the same way. Over the years Ive spent many late nights just tinkering under the hood. When shes running shes my daily driver rain or shine so it pays to keep up the routine maintainance. The more I replace the old with high quality new parts the more time I get to spend doing the fun stuff like adding cool Bond gadgets.
February 11, 2015 at 8:56 pm #263123they were tough to get a good look at.
I will be getting pictures tomorrow evening, and, will be getting lots of them, to use for reference notes.
February 11, 2015 at 9:13 pm #263124I dont know how to load pictures here but if you do then wed love to see them.
February 12, 2015 at 6:21 am #263125it’s a little tricky, sometimes, but, I should be able to get some up.
February 12, 2015 at 8:26 am #263126
February 12, 2015 at 7:32 pm #263127here’s some of the underside, and, still haven’t figured out what brand the rear shocks are.
February 13, 2015 at 6:25 pm #263128well folks, I’m even on my cars. had a grand tied up between 2 cars that a total of 15,000 was paid for the 2, but, now, I have 0 dollars invested in both.
shopping trip coming for parts.
February 15, 2015 at 10:45 pm #263129Looks nice. Cant wait to see the picts with her off the rack and some scenic background.
February 16, 2015 at 6:11 am #263130yea,
me too.
February 16, 2015 at 7:24 pm #263131ok, finally was able to get 1 shock/ spring assembly out. that was tough. now, for the real issue.
the PO had installed the wrong shocks, evidently, due to grinding down the bottom mount to fit inside the metal cup that the coil spring centers on, and cut 2 notches in it to allow 2 bolts to go down through to the bottom of the spring mount.
there is a 7/8″ center hole in the top and bottom spring mount that, I figure, is for the shock to mount into. plus, the top shock stud had been cut off some..
I figure that the shock that is supposed to go there has a stud mount on both ends.
can someone verify this for me?
I measured the total distance from top to bottom, and, came up with 14″, and, the spring measured 13 1/2″.
correct?
February 17, 2015 at 6:48 pm #263132I also found that the rear hubs lean in a little at the top, the driver’s side leans in a little more than the passenger’s side.
bearings?
February 17, 2015 at 8:38 pm #263133Is there any slop in the bearings? Can you wiggle the wheel by grabbing the tire top and bottom. The rear carrier/wheel bearings are not frequent failure items, and often last hundreds of thousands of miles.
The rear axles have likely been decambered one (or more) teeth on the splines of the rear torsion bars, in order to lower the rear ride height with the lighter weight of the fiberglass body. This can cause the tires to lean in, though not as much on the IRS rear suspension as on the swing-axle type. You can adjust this back higher in 3/16″ increments, though it’s not a simple/easy procedure. You can also buy adjustable end caps/plates that can be used to fine tune it even more. Here’s the procedure:
http://www.airheadparts.com/vw-rear-height-adjustment
Some people (including Roy on his TDr) use coil-over shocks and adjust them to address one side sagging….KentT2015-02-17 20:38:48
Slowly coming back from the ashes...February 17, 2015 at 8:53 pm #263134I currently have the wheels, coils, and shocks off, and want to fix my rear sagging issue, along with this wheel leaning issue. the driver’s side has more lean than the passenger’s side, but, the car sits level from side to side.
mine has the stock drum set up, not the disc type shown in the picture.
February 17, 2015 at 9:11 pm #263135Doh! My bad! Totally forgot that you have the aftermarket rear suspension also. 😡 Sounds like the trailing arms are not aligned the same, side-to-side. Your options are likely shimming the carrier or heating/twisting the trailing arm in question.
Slowly coming back from the ashes...February 18, 2015 at 6:28 am #263136i’ll know more, later today, when I get the wheels back on to test the bearings.
February 18, 2015 at 8:13 am #263137The stock rear shocks have a stud mount top and bottom.
February 18, 2015 at 10:05 am #263138dick whats the part # on your stock shocks and front?
thanxzFebruary 18, 2015 at 5:46 pm #263139I can get adjustable coil over shocks cheaper than the replacement shocks alone. wouldn’t that be a better replacement?
