I seem to have lots of problem with fuel pump .I know about alternator fuel pumps vs. generator fuel pumps and i have the right one.I’m thinking it is time to switch to a electric fuel pump.I’m assuming some of you have have done this any suggestions will help, which one to buy, where to buy it etc.
the problems are in the last month 2 months towed 3 times 1st tow replaced fuel pump 2nd tow no gas to carb.unhooked fuel line going in to pump a steady stream of gas into bucket, no gas comming out of pump no pressure out of pump 3rd tow hose nipple out of pump loosened up finally got it going . Just a frustation
I converted mine to electric about 20 years ago. Was on the road and the fuel pump went out, a “universal” electric replacement was the only thing the local auto parts store which I could walk to had in stock that would fit. It was on a weekend and could not have gotten a OEM mechanical replacement until Monday. Have removed mechanical pump and fitted cover over area. Have replaced the electric one once. You need one with a lower PSI output, 3-5 lbs I believe.
