Home › Forums › MGTD Kit Cars › VW Based Kits › MIGI Wiring
- This topic has 19 replies, 10 voices, and was last updated 11 years, 1 month ago by
Phil.
February 17, 2015 at 7:46 pm #235584
I have a MIGI not a MIGI II. Ot came with a wiring harness and a smaller sub harness (dashboard)?. I have the layout but there is no color code to tell me what goes where. Does anyone have a doc with color code? The harness is in good shape do I would like to use it but not knowing the color code might force me to buy a dune buggy harness or a 12 fuse street rod harness. Thanks!
Dbanta 2015-02-17 21:51:54 In wine there is truth, in water health.
February 17, 2015 at 8:41 pm #263207Have you downloaded the FiberFab build manual from the Downloads page? I think it has a wiring diagram in it?KentT2015-02-17 20:41:50
Slowly coming back from the ashes...February 17, 2015 at 9:30 pm #263208Yeah Kent I looked at that. I have the same diags in the MIGI II build manual that I have. No color code. I have been looking at the wires that I have to see if they are numbered but I do see any. I will continue to study it. I think if I had some idea of the color code it would make more sense.
February 17, 2015 at 9:41 pm #263209If you are a VW Daytona, and are not in a hurry, I could try and reverse engineer the thing by telling you what color codes I have. Let me warn you that a very large number of my (under dash) wires were numbered with small tags that have fallen off.
February 17, 2015 at 9:45 pm #263210Hey everyone
this is a great place to get some advice on auto electric and more. How-to-build-hotrods.com has helped me understand how to safely rewire my car. Im not a skilled at auto electric so if I can do it anyone can. It helped me get rid of a lot of extra wires and make the wire system look better. Im using the less is more approach on my car. The less complicated the system is the more reliable my car is also no hiding places for gremlins.February 17, 2015 at 9:49 pm #263211Yeah Roy, if you can even take a few photos that would be great. It is a MIGI Daytona. You can also PM me with the photos. Thanks!
Thanks Rick I will take a look at that site.
February 17, 2015 at 10:11 pm #263212Also two great places to look for switches and guages are socal speed shop and west marine. They have heavy duty switches that are more expensive than the ones that come with our kits but are worth it. I installed the switches without relays and so far no problems.
Socal speed shop also has some cool acessories like mirrors lights and much more.
Happy shopping!February 19, 2015 at 4:11 pm #263213Part II of the CMC build manual on the downloads page contains a diagram with descriptions of the colors. That might be a starting point to check. Wouldn’t be surprised for the supplied harness to be the same or at least very similar.KentT2015-02-19 16:16:21
Slowly coming back from the ashes...February 19, 2015 at 8:36 pm #263214I built my own wiring using a VW bug color wiring diagram and eliminated all the “stuff” I didn’t need or wasn’t part of the TDr (door switches, interior light, rear window defogger, etc.)I even added a horn relay, radio and 12V power accessory connector (cigarette lighter socket). You could always use the VW color for a guide.
"If one thing matters, everything matters" - from the book The ShackFebruary 19, 2015 at 11:27 pm #263215I salute your confidence with wiring, Allen. Anything beyond changing a light bulb is more than I want to tackle myself.
1981 Lafer TI
1600 cc Type 1 engineFebruary 19, 2015 at 11:37 pm #263216Speaking of wiring up accessories, does any one have any thoughts about adding a 4 way emergency flasher switch, and how to do so? Thanks
Dave
Lakeland, Florida
Where we drive topless every day. 😉Dave
Lakeland, Florida, where we drive Topless every dayFebruary 20, 2015 at 9:43 am #263217Not “regulation” by any means, but a friend jumped a wire from one turn signal’s hot lead, through a switch, to the hot lead of the other turn signal.
ÂWhen he needed 4-way flashers, he’d turn on the left turn signal, then flip the switch, sending power to the right turn signal.Paul Mossberg
February 20, 2015 at 11:59 am #263218Mine has the VW flasher
February 20, 2015 at 12:41 pm #263219edsnova wrote:Mine has the VW flasherMine also, including the emergency flasher switch…
Slowly coming back from the ashes...February 20, 2015 at 1:55 pm #263220Great discussion on four-way flashers on the Samba at:
ÂRelay recommendations, wiring diagrams, the whole nine yards.Paul Mossberg
February 20, 2015 at 1:56 pm #263221Good info here too:
ÂÂPaul Mossberg
February 20, 2015 at 2:07 pm #263222If I was doing it all over again, I think I would use an early VW steering column (without the key), reomve the VW turn signal lever, and use something like this:
ÂPaul Mossberg
February 20, 2015 at 2:10 pm #263223PMOSSBERG wrote:If I was doing it all over again, I think I would use an early VW steering column (without the key), reomve the VW turn signal lever, and use something like this:ÂThough most aftermarket are not self-cancelling, that would dramatically simplify things and reduce the spaghetti under the dash…
Slowly coming back from the ashes...February 20, 2015 at 4:29 pm #263224The hot rod sight I mentioned before has a section on how to add emergency flashers to an existing system. Good info.
February 20, 2015 at 10:42 pm #263225KentT wrote:PMOSSBERG wrote:If I was doing it all over again, I think I would use an early VW steering column (without the key), reomve the VW turn signal lever, and use something like this:ÂThis is what I did on mine. I thought that I would remember to manually
cancel the signal but after finding the signal still flashing a block
or two later too many times I added a low volume buzzer into the circuit
and wrapped some foam rubber around it to make it just audible.
Phil -
