Home › Forums › Picture Gallery › TD Replicas › Mystery Panel
- This topic has 11 replies, 3 voices, and was last updated 15 years, 3 months ago by
newkitman.
November 7, 2010 at 5:55 pm #233210
Hey Everyone,
I have a panel in my Fiberfab kit that I can’t identify. Any help identifying this thing is greatly appreciated. In case I don’t get the photos loaded correctly, the panel is rectangular and about 3/4 inch deep on the underside and shaped on top like the dash top.Thanks
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 9:50 am #242757Disregard the question. Found the answer in the Downlaod Manuals section. My assembly manual was missing a few pages. It’s the windshield defroster duct. Mounts the defroater to the underside of the dash. I guess the defrost air is not heated as it appears the defroster just intakes cabin air.
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 9:59 am #242758Allen, Thanks for the info,I was abuot to guess that it was a dashboard for a dune buggy.
November 8, 2010 at 11:26 am #242759Had me stumped for a bit. But per the missing page, this is an option on the CMC Fiberfab kit. You have to drill a hole in the center for the defroster blower output, mount the blower and then fiberglass the duct/pabel into the underside of the dash. The top of the dash gets the defroster vents to the windshield. Blower inlet just seems to be from the cabin as there are no instructions about what goes there.
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 1:24 pm #242760Allen, You may already know that the MG’s did not have defrosters. I suspect that the kit manufacturers included the defroster [actually defogger in this case] to comply with state requirements. My London Roadster factory built car has a 3in.vent in the center of the dash . It looks UGLY and serves no purpose since they mounted the blower with the intake flush against the inside of the firewall with no way for it to get any air.I removed the blower and installed it on my BCW where it can do some good bit I’m still left with the big ugly hole with the vent on the cowl of the other car.
November 8, 2010 at 2:42 pm #242761Larry, Didn’t know that MGs didn’t have defrosters. I suspect that is why CMC offered it as an option. In the downloaded pages that I was missing from my assembly manual I cut two 3 inch rectangular slots in the top of the dash ans insert the original VW bug defroster vents there making certain the vents point towards the windshield. I guess it’ll work okay but I dont expect any heat from them.
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 3:45 pm #242762I have a defogger in my Duchess….four round vents (probably an inch or inch and a quarter) along the base of the windshield. And a blower under the dash.
All it does is recirculate the air within the passenger compartment. But it works great.
Remember guys, most of this has nothing to do with what an original MG TD had. Heck, even heat was optional back then!
November 8, 2010 at 5:58 pm #242763Paul,
Did the defroster in your Duchess come with the kit or did yopu use a stock late model VW defroster motor? MG Magic has a defroster kit for $80 I think. Need the defroster for cear windshield when it rains me thinks.Allen Caron
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 6:00 pm #242764About the heat. NGs weren’t the only British cars without heat. I was stationed in Felixstowe, Englad in the late 70s and had a mini coop. It didn’t have heat either. A blower yes but heat….only if I blew hot breath on my hands.
"If one thing matters, everything matters" - from the book The ShackNovember 8, 2010 at 11:56 pm #242765It is not a VW defroster. Just a simple blower.
Somewhere in the vast recesses of this forum, I think there is a link to the sort of blower I have. I’ll search for it.
November 9, 2010 at 12:10 am #242766All you need is something like this, wired to an on/off switch
http://www.boatersland.com/att17314.html
Mount it under the dash. Fabricate an adaptor and run hoses to whatever vents you are using along the windshield
November 9, 2010 at 6:54 am #242767Paul, I actually have two of those in my shed. I was going to install them in the Ghia but changed my mind for some reason. I evem have the clamps and hoses. Got them on eBay.
Thanks for the info.Allen Caron
