Home › Forums › MGTD Kit Cars › My Project › New dashboard project
- This topic has 105 replies, 13 voices, and was last updated 11 years, 10 months ago by
ray10.
February 19, 2013 at 9:41 am #253704
I like it. And apparently so does the chipmunk who is about to bless it with a little flower. Is this the front or rear side?
"If one thing matters, everything matters" - from the book The ShackFebruary 19, 2013 at 10:13 am #253705ED.
You have done a superb job on the dash….Your finish is beyond perfection…jebarry2013-02-19 10:38:06
February 19, 2013 at 10:55 am #253706Thanks guys. It looks pretty good. It’s nowhere near perfect though, as a close examination will reveal.
Usually, good enough is good enough.
February 19, 2013 at 11:41 am #253707The work accomplished on that dash rivals Norm of New yankee Workshop. You keep it up and we’ll start calling you Norm 2! And you did it WITHOUT all his expensive equipment and workshop.
"If one thing matters, everything matters" - from the book The ShackFebruary 19, 2013 at 12:57 pm #253708Nice job. That looks too good to leave out in the sun and weather. Is that coating going to be UV resistant?
February 19, 2013 at 1:56 pm #253709Marc, the Pelucid undercoating with Helmsman Spar Urethane (which is UV resistant) on top was tested for years in the weather and did the best of several combo packs. Another guy in FL did a similar test and got similar results with the Minwax. Given that my car spends all winter and most summer weekdays in the garage, I’m thinking this finish should be pretty durable.
February 19, 2013 at 2:38 pm #253710It looks great and I hope it lasts a number of years. It would be a real pain to have to remove the gauges and switches from the dash and resand it and apply more layers of topcoat. But then it’ll look great for another few years.:-)
February 23, 2013 at 5:15 pm #253711Cowl respray. 45 degrees in the garage today but I lit a fire and got it
into the mid 50s, which is OK for the primer but a bit chill for the
Duplicolor. We’ll see what it looks like in the a.m.
February 23, 2013 at 6:01 pm #253712Well, the photo looks good.
"Drive Happy"February 24, 2013 at 8:56 am #253713It’s not terrible. Warming up the garage again & wil post more pics later.
February 24, 2013 at 10:33 am #253714Ed…is that color MG Red? Looking at the colors used for MG TDs they had two different reds. One was MG red and the other was a darker red. Mine is a brighter red (that I think) is MG red. The can of jet coat that came with the kit doesn’t say what color it is…just red Jelcoat handwritten on the can. newkitman2013-02-24 10:44:28
"If one thing matters, everything matters" - from the book The ShackFebruary 24, 2013 at 11:57 am #253715My car was green when BCW gelcoated it circa 1980. It was resprayed in the late 90s or early 2000s by the P.O. The color is Ford Toreador Red, which they shot trucks, LTDs and Tauruses with from the mid ’90s through about 2000.
A metallic pearl formulation of some sort, Toreador Red is nothing like any paint Abingdon would have used on an original TD. This is a fact that a “real MG” owner once pointed out to me, rather curtly, in asking why I had my TD painted that color.
(You can see both colors below. Sanded last night’s work with 2000 grit and cleaned it, hit it with thinner and then a tack rag and shot two more light coats, allowing some overspray on the top so I can blend it later with compounding paste if needed. I’m gonna let this cure for a week or two and see what it looks like before fussing with it more):
edsnova2013-02-24 12:10:15
February 24, 2013 at 5:58 pm #253716Looks pretty good.
"Drive Happy"February 24, 2013 at 6:06 pm #253717looks like a good match…!
February 24, 2013 at 9:48 pm #253718Yeah. I’m thinking the same. I’ll probably roll her out into sunlight next weekend just to be sure, but my feeling is that this is going to work.
March 2, 2013 at 8:47 pm #253719After a bit of work with the 2000 grit and a hand rub, the paint matches well enough. If you’re looking for it you cans see what I did. But you’ll have to be looking for it.
March 10, 2013 at 8:08 pm #253720Well almost done now. Just have to figure out how to tuck up/secure the ends of the welting you can see hanging down. Also, gotta secure the tach.
60 degrees today. Couldn’t resist a test drive today after doing a lot of other chores. There are still a lot of things to do, but the dash is all screwed down, the glove box is in and operational, and electrical stuff pretty much all works. The emergency flashers don’t flash but I do remember shorting out the flasher while messing around under the dash. so that’s probably it.
Gotta tie up some loose wires, change out the carpet on the rear deck, and then it’s on to the spring revival stuff: grease, tuning, and–I still can’t believe it–putting new/different oil in the transmission??
Who does that?
I guess I will.
Carlysle is coming up fast.
March 10, 2013 at 8:49 pm #253721love your car..
March 11, 2013 at 11:19 am #253722Ed
Cut a wedge out of the flat part of the welting (do not cut into the stitching by the head).
Fold it, glue it, and trap it between the dash and the fiberglass. PMOSSBERG2013-03-11 11:19:31
March 11, 2013 at 3:22 pm #253723Ha! Stitching? We ain’t got not stinkin’ stitching!
The welting is already between the ‘glass and the wood. On the originals it folds under and, I assume, gets tacked to the back of the dash. If I were thinking ahead I would have attached it to the dash back all the way around before I installed the dash. And I would have put some kind of hook or loop on the glovebox or the back o the glass to tie off the welting.
I will figure it out though.
Wait! Hook. Loop….
I think I got it….
March 11, 2013 at 6:24 pm #253724Open up the welting a bit and remove the cord/plastic tube back to the point where you want to fold. It will be easier to fold it back and hide the excess.
March 11, 2013 at 10:02 pm #253725And . . . done. I used stick-on velcro. And yeah, took the last bit of rope out, refolded, trimmed.
Here’s the side I shot with Duplicolor. Looks a tad better than the door top, which has some fisheye. I guess I’ll have to get to work with the wheel if I ever want it to look as good as Schu’s or Roy’s.
March 11, 2013 at 10:15 pm #253726Ed, If I could, I would trade my dash for yours. It looks terrific and it’s unique. It’s home-made and it has personality. I’m jealous, but not so jealous that I want to undertake all the work that you put into it. Whoever steals your car, will never be able to join the tdreplica.com club.
March 12, 2013 at 8:52 am #253727Sure they can join. We’ll take anyone!
Seriously…GREAT work Ed!
March 12, 2013 at 9:04 am #253728Ed,
Nice – now all you need is some plaid pants and you will match
. Looking forward to seeing in person. -
