Home › Forums › MGTD Kit Cars › VW Based Kits › New Gas Tank
- This topic has 4 replies, 4 voices, and was last updated 14 years, 5 months ago by
Tom Colello.
September 14, 2011 at 5:16 pm #233692
Hated to do it but my factory tank left me no choice so I ordered a new aluminum tank last week and installed it last Friday. The build in fiberglass tank was all eaten up. Don’t know how gas was getting through to the engine. Don’t know if ethanol blend gas had anything to do with the degradation but I’ve heard it’s bad on FRP tanks.
I drained the exhisting tank and dried it out with a fan then vaccumed out all the crud. No glass cloth which was a surprise but lots and lots of loose resin crystals. Had both tank outlets blocked to the point where I had to poke a screwdriver through to open them up. Then I installed the new tank on top. It takes up valuable trunk space but it is a necessary evil. The tank is 14x20x8″ tall. I get about 9 gallons out of it. Here’s a couple of pics. A sample of some of the broken down resin that was throughout the tank
The access hole that was cut by a previous owner which tells me I’m not the first to have gas tank issues.
The new tank
The new tank installed
September 14, 2011 at 6:01 pm #246528Where did you buy that pretty tank, just in case other forum members have to replace their original tanks.
September 14, 2011 at 11:17 pm #246529That’s the problem with ethanol blended fuels -dissolving the resin in fiberglass tanks. This has been a problem noted in the marine industry for years. You are lucky you didn’t have the tank come apart and seriously leak all over the place. Nice looking new aluminum one though. Could you have gotten one a little taller or longer for more capacity? Was this a stock size or custom made?
Why are there 2 lines going into your tank?September 15, 2011 at 5:31 am #2465302 lines are a nessary evil,1 for feed 1 for vent/or return line on fuel injected
September 15, 2011 at 1:14 pm #246531I went with as small a tank as I could to preserve some storage space in the trunk. I had it custom made by Boyd Welding in Ocala, Florida. They do have standard sizes but I opted for a custom size. They will build any design you need. They did an excellent job and I highly recommend them. I ordered it on Thursday the 1st and had it in my hands the following Friday ready to be installed. You can find them on the internet or call Dan Hance at 352-447-2405. Super nice folks. I paid $277.00 including a new sending unit and two internal baffles delivered. Check out their web site boydwelding.com.
Besides the filler neck on the top there’s the sending unit and vent line. This winter I’m gonna do away with all the rubber line I can and go with AN fittings and hard line. I just went this way for now to get the car back on the road quickly so as to not miss any cruisin weather.
