newbie with a fuel tank question
Home › Forums › MGTD Kit Cars › VW Based Kits › newbie with a fuel tank question
Viewing 3 posts - 26 through 28 (of 28 total)
  • #251098
    sreynolds
    @sreynolds
    Thanks….I’ll have to start looking for an good used earlier gas tank. I think that would be the easiest route to go so I just have to shorten the filler neck. Hope I can find one locally.
    Sam
    #251099
    Royal
    @royal
    Sam, I would be very surprised if Simmons VW Restoration (just outside or New Bern) did not have a tank that would work for you.  But, be advised that you may have to have it cleaned out – not always an easy task.
    This place is about 2 miles from my house.  Shop: 252 637 5698 or Cell: 252 675 1200.  You will be talking to Dalton Simmons.
    I could check it out for you.
    Give me a call.
    #251100
    KentT
    @kentt
    Worst case, there are Brazilian/Mexican made new ones on the aftermarket for about $125.  But, a good used German original is the best bet if you can find one close.  IMO, a used one MUST be inspected before buying because if people have left this ethanol gas sit in they, they rust badly from the inside out…
