Home › Forums › MGTD Kit Cars › My Project › Noob questions — Round Two!
- This topic has 10 replies, 7 voices, and was last updated 13 years ago by
newkitman.
March 6, 2013 at 1:43 pm #234559
Since it looks like I’m zeroing in on a FiberFab VW-based car (even have a “back-up” plan identified, should choice #1 fall through), it’s time for the next round of noob questions.
1. Tires: What type/brand/size of radials are VW owners using? I’m looking at 185R-65/15s which seem to be about the same height, and only slightly wider, but will still fit the stock VW wheels. There’s many more choices there than with the stock 165-15 VW size. Do you think I’ll have any interference problems?2. Any specific tire recommendations — either to avoid or to buy? Tried searching but found no real discussion of this…3. What lapbelts are you using? Neither kit that I’m looking at has lapbelts. I doubt there’s enough room for retracting lapbelts, but if anyone has found a way to do that, I’d like to hear about that also…Thanks for the patience and the help!Early FF TDr on 69 VW pan
Slowly coming back from the ashes...March 6, 2013 at 2:32 pm #254881I have 185R-65/15s on my Duchess. I don’t recall the brand, but will check. Your options are pretty limited in this size.
I have non-retracting lap belts. They came with my kit; I don’t know the brand. To be honest, they are pretty much for show. They hold my butt in place during spirited drving. But they bolt through huge washers which sandwich the fiberglass body between them. In the event of a real wreck, I’m pretty sure they would tear right through the fiberglass. I rationalize it pretty easily tho. If the accident is that bad, the car is gonna crumple. And I’m toast with or without belts.
March 6, 2013 at 3:05 pm #254882March 6, 2013 at 3:21 pm #254883My lap belts are bolted to the tunnel and a ridge in the metal floor pan. Threaded holes–possibly originally for the VW back seat belts?
Maybe a little better than just through fiberglass but Paul’s analysis applies to all of these cars. Don’t crash.
Mine are really old, maybe original to the build. I might splurge on new ones, maybe upgrade to the 3-inch web and aircraft latches…
March 6, 2013 at 5:17 pm #254884MG logo seat belt
ray102013-03-06 17:19:24
TDREPLICA Map
March 6, 2013 at 5:31 pm #254885My set is like ray10s only red to match the color of my car. I plan on attaching them to the tunnel and a body-to-pan bolt at the body rear attach points.
"If one thing matters, everything matters" - from the book The ShackMarch 6, 2013 at 5:46 pm #254886Yeah, I don’t think blue would work well on a red car with white interior, either…
But, those NAPA retracting ones are interesting, once I see how much space I have to play with…
Slowly coming back from the ashes...March 6, 2013 at 6:15 pm #254887Wonder if there is enough belt to come from behind the seat and up and over the shoulder to the attachment? If not then the regular ones we have will have to suffice. And I’m not certain that the original TDs had a seat belt requirement back then.
"If one thing matters, everything matters" - from the book The ShackMarch 6, 2013 at 6:38 pm #254888Allen, no seat belts on originals.
March 6, 2013 at 9:10 pm #254889When i was looking at changing the seat belts on mine , they told me I could get them in any color I wanted the price went up on special orders .
Allen their were some cars that had a seat belt that went thu a loop on top of the seats by the head rest and down to the floor . I can’t remember which ones they were but you might try a wrecking yard for some?ray102013-03-06 21:13:09
TDREPLICA Map
March 6, 2013 at 11:08 pm #254890Yep! I know which one…my 74 Ghia had those.
