Home › Forums › MGTD Kit Cars › VW Based Kits › Pedal Assembly
- This topic has 4 replies, 4 voices, and was last updated 14 years, 7 months ago by
July 31, 2011 at 5:51 pm #233577
Has anyone dealt with the pedal assembly on the VW kits? On my car the pedal stop for the clutch looks as though someone used a piece of mangled angle for it. Does this pedal stop work for the clutch as well as the brake pedal? Also, the brake pedal return spring is attached to the pedal and nothing on the other end?? Should the pedals in the resting postion by side by side? Oh what fun!
July 31, 2011 at 6:42 pm #245530jhbyrd,
The brake pedal spring has a hook on one end and a straight end on the other. The hooked end goes over the brake pedal post like you stated. The other end either sits against the floor pan or like mine fits underneath the pedal assembly and the floor pan.Allen Caron
"If one thing matters, everything matters" - from the book The ShackJuly 31, 2011 at 9:20 pm #245531i had to replace my pedal assembly .there are a couple posts and pics if you do a search on this site. found a good used one on ebay . basicly there are two different ones, early and late model. i think about 1968 and later have a mount for the gas pedal built onto it.
that piece of “mangled angle” is used to keeep the pedals from falling forward to the floor and the clutch cable coming loose in the tunnel.this is NOT a fun project. hope you can repair yours in placeJuly 31, 2011 at 10:30 pm #245532When the brake and clutch pedal are not pressed in they should both be almost vertical and line up with each other. Not sure what your setup is. The pedal stop should be a nice bracket looking device that has an elongated hole to allow adjusting the pedal stop. Can’t remember if the pedal stop affects the clutch pedal.
"If one thing matters, everything matters" - from the book The ShackAugust 1, 2011 at 7:49 pm #245533Post photos, J byrd. I had my pedal assembly out of Bridget over the winter. bit of a PIA to remove and replace, but not nearly as bad as, say, rear torsion bar reindexing. Everything can be done by you with hand tools, most likely.
