Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Pedals height increased
- This topic has 8 replies, 3 voices, and was last updated 10 years, 11 months ago by
February 25, 2015 at 10:06 pm #235606
To increase pedal height, I dropped the floor 1 1/2 inches. This puts floor to depth of frame rail.
Chevy 2.8 V6, 5 speedFebruary 25, 2015 at 10:55 pm #263373Terrific Ric! Glad to see this worked out!
February 25, 2015 at 11:10 pm #263374Very TD-ish solution. There is a rubber footwell liner you can get from Moss that replaces the same part on the originals–though they only sink about an inch. I have one in Bridget, as seen here.
February 25, 2015 at 11:18 pm #263375Still have to adjust pads, but much easier to push pedals now. I do like the roller pedal. Where can they be gotten?
Chevy 2.8 V6, 5 speedFebruary 26, 2015 at 10:38 am #263376Google “roller accelerator pedal” and you are going to find dozens of hits for the VW pedal assembly.
But I’m not seeing anything for Chevette or Pinto pedal assemblies.Paul Mossberg
February 26, 2015 at 8:01 pm #263377I replaced the big roller with a small caster wheel to get it closer to the original TD size. If I had a Chevette stule gas pedal arm coming down I might think about welding the caster holder to the end of it and calling it a day.
Key is getting something narrow but workable. The only value of the roller, from a practial standpoint, is that it fits in that narrow footwell.March 28, 2015 at 5:16 pm #263378I removed the gas pedal, heated and bent it upwards. I now have more clearance to push brake pedal and I can get the throttle fully open. So I will not bother with a roller. Pedal operation is much improved over the original setup.
Chevy 2.8 V6, 5 speedMarch 28, 2015 at 8:32 pm #263379
March 29, 2015 at 10:42 am #263380Another happy ending!
