Home › Forums › General Discussion › Pow Bang Pop….
- This topic has 9 replies, 4 voices, and was last updated 10 years, 4 months ago by
Royal.
November 25, 2015 at 2:00 pm #235946
Hi All – Happy Thanksgiving….I just put one of these on my H5 1500 VW type 1 motor.
http://www.ebay.com/itm/391285896150?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
It is a 30Pict 1 carb that should wotk on my H5, I was hoping it would cure my old 30Pict 2 ills. It went on there fine but I get a lot of backfiring until it the motor warms up. At idle it runs great but under load I still get some sporadic backfiring. I checked the timing and I just adjusted the valve lash because I thought that might be the issue. The Choke needed some adjustment and I did that as well. I am wondering if my intake manifold might be causing a vacuum leak. It still has the original (?) intake manifold. I have scowered the internet and read most of the basic blogs on VW backfire and they all say the same thing. (Valves, timing, throttle body leak at the butterfly). Any thoughts? – Thanks! Dean
PMOSSBERG 2015-11-26 00:38:13 In wine there is truth, in water health.
November 25, 2015 at 3:47 pm #266369A huge Thanks to Royal for spending some quality time on the phone with me going over this issue. I have a few things to check. I will post when I find the solution.
November 25, 2015 at 4:37 pm #266370I just adjusted the Volume screw on the carb and now it doesn’t seem to backfire in the garage. I could make it backfire by quickly open the throttle (full throttle). I have only the one adjustment screw (Volume) on my 30 PICT 1 carb. Tomorrow I will check the timing again. According to Rob and Dave – I should set the idle timing at 7.5 degrees (1300/1500/1600cc
with single vacuum distributor – 7.5BTDC. This is set with the
engine off (static timing).) http://www.vw-resource.com/30PICT2.html – not sure why my font and I don’t see a way to change it back.In wine there is truth, in water health.
November 25, 2015 at 9:06 pm #266371Make sure the preheat manifold is not rotted out. Mine was–and hidden behind one of the air hoses that comes up through the tin on each side of the engine, so I didn’t see it. She’d backfire like crazy on decelleration until we patched it up with tape…
November 26, 2015 at 11:19 am #266372Thanks Ed, I will be checking that out.
November 26, 2015 at 12:01 pm #266373Dean
Have to look but might have a heat risor in my stuff someplace if you have a hole in yours.
Let me look – yours for the asking.
Going driving today?
Getting ready to go out for a run.
60 degrees going on 65.November 26, 2015 at 1:07 pm #266374Thanks Schu. I will happily take your cast offs. 🙂 cant do today. Tomorrow might be doable. Stop by or I can make a trip to your garage.
November 27, 2015 at 5:09 pm #266375
Update – Seems I had the distributor timing wrong. Schu came over today and, taking Roy’s and Schu advice , I makes a 30 degree mark on my crank pulley. Schu open the throttle to 3500 rpm and I was able to dial in the 30 degree mark. Wow – What a difference. No more Pop, Bang, Pow and the car has power. I am still not sure if I don’t have a very slight intake manifold leak (because I see a little wetness at the tube junctions) but that could be from something else. Anyway times to 30 degrees at 3500 rpm did the trick. Thanks for your help guys!!!
We had to go for a putt afterwards. He we are at Fairview Beach on the Potomac river.In wine there is truth, in water health.
November 27, 2015 at 6:36 pm #266376Great news! And a great day to cruise about. Lookin’ good, gentlemen.
November 27, 2015 at 7:21 pm #266377Dean, now you may want to re-tweak your carburetor F/A adjustment.
