Home › Forums › MGTD Kit Cars › VW Based Kits › Rust in gas tank
- This topic has 26 replies, 8 voices, and was last updated 9 years, 6 months ago by
October 1, 2016 at 4:25 pm #301952
Hi all, I’m new to the group. I hope that someday my Migi TD will look like some of yours but for now I’m just trying to get it to run. My gas tank has a lot of rust inside, should I try to clean it or just replace it? Thanks for any input.
Gary
October 1, 2016 at 8:32 pm #301953Are you positive that it is rust? Old gas with ethanol will deteriorate and a yellow coloured sand like precipitate will be deposited in the bottom of the tank and clog up fuel lines, pumps and the carb. You have to physically remove the crap, blow out or replace the lines, pump and carb. If you are not sure it is rust, test with magnet. The recommendation before replacing the tank is to remove tank, drain fuel, flush with muriatic acid, wash with gas to neutralize the acid, air dry then coat interior of tank with POR. Make sure port to fuel line or shut off value is not plugged with POR
Let us know how you make out as I expect others will offer their recommendations for alternative actions if more info is forthcomingDavid B Dixon
SabineOctober 2, 2016 at 11:17 am #301956Thanks for the input. When I removed the tank and shook it upside down the particles and chips that came out were typical rust color. Do you recommend I should still go with the muriatic/POR treatment? Thanks
GaryOctober 2, 2016 at 1:32 pm #301957As you have the tank out of the vehicle you will have to assess how extensive the rust is This can be done with a scope inspection camera, light and mirror, tapping outside of the tank where the rust is or poking the tank with an awl to determine extent of rust and whether integrity of tank has been compromised. Have heard of some who have tried fibreglassing tank from exterior cutting out rust and welding in patch. Welding should only be done by those with experience as gas fumes and heat from welding can create a dangerous situation. If going the fibreglass route you still have to try and arrest the rusting in the tank (muriatic acid/POR). Recommend you compare cost of replacement tank (MGmagic) and cost of repair to make a decision
David B Dixon
SabineOctober 2, 2016 at 2:43 pm #301959Gary,
MG Magic only has VW tanks
If you TDr is VW based, buy from one of the VW parts vendors. Just one example, CIP1 sells them for $143.99.
MG Magic wants $168.99 for a VW tank.
If you have a front engine car, I believe you will have a bit of a problem finding a replacement, unless your manufacturer used the donor vehicle tank.
October 2, 2016 at 3:41 pm #301960I removed my leaking tank and still need to get a new tank. Been using a portable plastic tank, a little 3 gallon size, for a year now. 50 mile range without worry and haven’t actually been motivated enough yet to get the new metal tank.
MG Magic has the correct tank and instructions for cutting and welding the filler neck so it will fit under the hood. See their page:
http://www.mgmagicclassicmotorparts.com/gas-tank-vw-mg-td-replacement/
Must be sure you get the correct tank if you buy someplace else, there are larger tanks and vary by year too. I can’t say if nothing but one type will fit or not but apparently a larger (10+ gallon?) tank wouldn’t. I’m just going to get the one like MG Magic sells.
The air vent tube can’t be used for VW version. Need vented cap, which you probably have already.
I believe a new tank will need to be cleaned before using them or welding too, something about rust preventative in them I think.
Bob
October 3, 2016 at 9:49 pm #301973Thanks for all the input guys. I’m gonna try cleaning the tank using some of the suggestions mentioned. I will let you know how it turns out.
GaryOctober 4, 2016 at 9:51 am #301976If you are able to clean the tank and it is serviceable, I recommend you seal it with something like POR-15 Fuel Tank Sealer.
October 4, 2016 at 3:02 pm #301981Regarding the vented cap – I started out with a vented cap but got complaints from passengers about gas smell. Since the evap system from my engine was long gone I ended up switching to a non-vented cap, adding a vent at the highest part of the fuel tank and routing it under the chassis to the rear of the car.
October 4, 2016 at 9:18 pm #301985I agree with Kall. Edsnova taught me how to do this. The hardest part is finding a capillary tube, and the scariest part was drilling a tiny hole for it into the gas tank neck. Once that was done, it was just a matter of gluing the tube into the neck with the right kind of epoxy and routing the capillary tube. I looped mine up over a little piece of wood and then down through the “hood” to a place near the front wheel. Never smell gas, and don’t get that “whoosh” when I open the tank any more. With the vent, I also don’t starve my carburetor any more. Thank you, Ed!
October 5, 2016 at 7:35 pm #301996I put fluid into the tank and there’s a leak larger than a pin hole so I’m on to plan B, replacing the tank. Cip1 is out of stock, MG magic has them for $168. I see Parts Geek has one for $108 and the filler neck looks like it won’t need to be cut. Has anyone used Parts Geek before?
October 5, 2016 at 7:48 pm #301999That’s the type with the filler neck on that shallow end angled corner I was talking about before.
You would either need to find a way to connect a filler hose leading out to somewhere, or remove that neck and move it to the opposite corner.
To have it the same way ours are (passenger/windshield corner) means welding a plate over where that low forward facing neck is (assuming not installing backward) and cutting a hole for it into the deep corner.
BTW, can’t recall ordering from Parts Geek before.
October 5, 2016 at 8:04 pm #302003Just get the early one–61-67. You might need to cut the filler neck down a couple inches. Test fit carefully, scribe it and then take it to a muffler shop to be cut and welded before you clean the Cosmoline out. They’ll charge you $20 or $30 to do it. Maybe less you you tell them what it’s for and come in with a six-pack.
Note: don’t buy the 15-gallon “extra capacity” tank. You’ll never need the capacity and it probably won’t fit.
Lots of options in stock:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111201075C
http://www.mamotorworks.com/vw/subcategory/vw-fuel-tanks
etc.
October 5, 2016 at 9:34 pm #302008Why an early one 61-67 and not a 1970, the year of the donor? Thanks.
October 5, 2016 at 10:17 pm #302009Gary
You have posted you have a MiGi TD, if you look at the two tanks on the http://www.mamotorworks.com/vw/subcategory/vw-fuel-tanks site for <68 and >69 you will note a difference in the tank configuration. Suspect that MiGi body design was engineered to use a <68 tank so maybe a >69 will not fit in space for tank. I have a MiGi on a 68 chassis and have the <68 tank installed and do not think the >69 tank would fitDavid B Dixon
SabineOctober 5, 2016 at 10:38 pm #302010They all want the earlier tank because the filler neck in the later one is laid down to accommodate the external fuel door. You can use that one in a TDr but you’ll have to relocate the filler neck as described. If you need an new tank it’s easier to get the older style tank & shorten the neck. Sometimes you get lucky and don’t even need to mess with it.
October 6, 2016 at 7:53 am #302012So the filler neck on the older tank is on the front driver side?
October 6, 2016 at 8:23 am #302013Filler is located on the passenger side of tank
David B Dixon
SabineOctober 6, 2016 at 11:18 am #302014Mine is located on the driver side. Is this unusual?
October 6, 2016 at 2:32 pm #302015Not necessarily, depends on which way the hood (bonnet) opens. On mine the hinges are on the driver side of hood so access to the filler on the passenger side makes sense
David B Dixon
SabineOctober 6, 2016 at 5:31 pm #302017So with my tank filler being on the driver side front what would be the downfall of the tank from parts geek, Part Number: 17321-05442102. Thanks.
October 7, 2016 at 12:25 am #302023So with my tank filler being on the driver side front what would be the downfall of the tank from parts geek, Part Number: 17321-05442102. Thanks.
Probably would require a hose put onto the horizontal inlet tube that can reach above the top of the tank, 90 degree elbow for example, and a way to put a cap on that. Likewise for the smaller tube opening next to it, or plug it somehow. So getting it above the top of the tank and positioned solidly might be the most difficult thing to do.
I’m only guessing. You really need the advice of someone with that particular tank setup or has done it before.
October 7, 2016 at 9:35 am #302027As was mentioned above, the “left side/right side” issue is relative to which way your hood opens.
You want the filler neck on the same side as the opening.
if the filler is on the same side as the hood hing, it’s difficult to get to.
October 8, 2016 at 9:25 am #302043Thanks for the info. I understand that the filler neck needs to be on the same side as the hood opening I was wondering if the hood opening on the drivers side was unusual.
October 8, 2016 at 9:52 am #302044Nope, not unusual. The guy that put your kit together pretty much had a choice of where to put the hinges. Flip a coin. (BCW excepted) My Daytona hinges on the passenger side, but it really doesn’t matter.
