Home › Forums › MGTD Kit Cars › VW Based Kits › Splash Pan Fit
- This topic has 8 replies, 5 voices, and was last updated 12 years ago by
newkitman.
March 29, 2014 at 8:24 pm #235138
The last hurdle for my TD is the splash pan. When you install the splash pan the forward lip bolts to the vertical piece of the body tub. Mine is an inch short. Been thinking about a remedy and at the moment my options appear to be:
1. Wait until I install the engine to see if I need to shorten the metal brace an inch on both sides, cut and re-weld.2. Add some fiberglass pieces to fill the gap on each side so the splash pan bolts to the body like its supposed to.3. Leave it as is and not worry about it.If anyone has any other options, please chime in.Oh! My kit is a late Fiberfab/CMC kit.Allen Caron
"If one thing matters, everything matters" - from the book The ShackMarch 29, 2014 at 10:00 pm #260057My Duchess went together differently.
But from what you’ve described, I vote for #1 for now.
How do the splash pan and engine cover line up? Have you test fit that?
March 30, 2014 at 12:29 pm #260058What holds that square tube subframe to the car? Mine is clamped to the frame horns and, theoretically, could be slid fore and aft a bit if needed. My splash pan sits on it and bolts through–top to bottom and in the back, where the bumper bolts through to two tabs of angle iron that come off the back of the square tube.
March 30, 2014 at 1:57 pm #260059Mine is a Ford based late FiberFab and I had the same problem. The splash pan came a little over one inch short of reaching the tub (body) when fully forward and against the bumper mounts. With the rear cover in place against both the tub and spash pan, there was also a gap where the rear cover didn’t cover the cutout in the splash pan.
The the frame extension to bumper mounts is a welded assembly with no provision for adjustment. I decided to shorten the bumper mounts by cutting out a section of the tube and rewelding to obtain the length that allowed a good fit of tub, rear cover and splash pan. I guess that means the car is about 1 1/4″ shorter than intended.Don Loveless
Ford Pinto Fiberfab
Rochester, MIMarch 30, 2014 at 5:39 pm #260060Ed. Mine fits like yours and has a small gap (about an inch). I don’t have the engine build complete as yet so its not installed. Neither is the rear engine cover or splash pan. I’ll take a couple of pictures of as it sits and the gap when I raise the tube subframe tomorrow after work.
"If one thing matters, everything matters" - from the book The ShackMarch 31, 2014 at 10:33 am #260061Mine is an early Fiberfab and the splashpan also does not reach the back of the tub. I’ll likely use a piece of aluminum to bridge the gap, when I also try to modify the splashpan to fit the engine tin at the rear of the car. My splashpan has angular sides and does not match the curve of the VW engine tin at all…
Slowly coming back from the ashes...April 1, 2014 at 8:07 am #260062The bottom of the engine cover rests flush with the splash pan. I don’t imaging the space will be all that noticeable with the rear fenders and welting installed but still feel the splash pan has to be connected to the body. I kept the fiberglass that was cut out for the gas tank. That is more than enough to make some filler pieces to fit between the body and splash pan. I’ll keep you posted.
"If one thing matters, everything matters" - from the book The ShackApril 1, 2014 at 10:06 am #260063Allen,
That “gap” could be intentional. On an original TD, the splash pan ends and there is a bit of a gap.
PMOSSBERG2014-04-01 10:07:08
April 1, 2014 at 12:21 pm #260064Paul,
That could very well be. On an original TD, the splash pan looks to be supporting the bottom of the petrol tank. On our TDrs, the splash pan appears to allow the engine cover to rest on it. I’ll do some pondering…(ponder, ponder, ponder). After a proliferation of pondering (whew) I will stick close to original and leave the gap. Now where did I leave my pint o beer and my sandals?
newkitman2014-04-01 12:22:22
