Spring loading
Home Forums MGTD Kit Cars Chevy/Ford Kits Spring loading
  • #304248
    David O’Neill
    @davdbrockton
    I have a TD on a Ford frame and the springs are too hard for me. The front weight is 850 pounds on the double wishbone setup. The original was probably around 1050 pounds. Any idea what the rating should be to soften these a bit?
    • This topic was modified 8 years, 5 months ago by Paul Mossberg.
    #304250
    billnparts
    @billnparts
    I’m running Alden Eagle coilovers with 500# springs. I remember running those original springs. They’ll knock your teeth out.
    "Drive Happy"
    #304255
    DonsMG
    @donsmg
    I built my FiberFab Ford kit on the FiberFab frame about 7 years ago. The ride height in the front was too low with the original Ford coils that had two coil turns removed. I replaced with 275 lb Heidts springs from Summit Racing shortened by 1 1/4 coil turns. If I had it to do over, I would shorten the coils an additional 1/4 to 1/2 turn to set the ride height lower by about 3/4″. The ride is great for normal street use, I don’t do hill climes or autocross.
    Don Loveless
    Ford Pinto Fiberfab
    Rochester, MI
