Stiff shifter
Home Forums General Discussion Stiff shifter
  • #234495
    Mark Konrad
    @mark-k
    My shift level is very stiff, hard to shift.  When I parked/stored it this summer for a few months it got stiff all of a sudden, never a problem before.
    Any ideas how I can resovle this issue?
    #254289
    Royal
    @royal
    Are you sure that it is the lever and not the transmission that is causing the stiffness?  I know that some folks put synthetic transmission fluid in to allow for easier shifting when it’s cold.
    #254290
    Mark Konrad
    @mark-k
    Not sure.
    I think a will unbolt the shifter on the tunnel and see whats going on there first then double check the trans.  Shouldn’t be because its cold because I ive in Florida and the weather is in the 80’s.
    May try repplacing the trans fluid if can’t find a problem in the tunnel area.
    #254291
    Royal
    @royal
    You should get another opinion.  I’m just an old amateur mechanic who makes errors.
    #254292
    Mark Konrad
    @mark-k
    Thanks your not alone.  I’m just and Old fart just trying to learn.
    #254293
    newkitman
    @newkitman
    Mark
    Check the coupler that connects the shift rod to the transaxle under the tunnel access panel. Sometimes the coupling gets worn or the bolt gets hung. Usually a new couplling will cure the problem. Let us know what you find out.
    #254294
    Hi,
    Go through the gears with the engine off. If it is stiff or feels like it is binding, it is likely the nylon bushing in the shift rod bracket.
    It it moves freely, start ‘er up and go through the gears again. if it is stiff, it;s likely the trans issues mentioned in earlier posts.
