Tach problem
Home Forums MGTD Kit Cars VW Based Kits Tach problem
  • #307986
    Bud Hedger
    @budman53
    My tachometer is showing less than 1500rpm at 55mph. Idle speed rpms are normal. Any ideas, short of replacement?
    #307987
    John Harrison
    @justjohn3
    Have you tried reaching out to VDO or whatever brand your tach is? Sounds like it might be more of a factory tech service situation than a DIY. That said, did your tach ever work correctly? If it’s always been wonky, there may be calibration switches on the back, but you probably still need mfg’s input to set correctly. Rambling further, if there is a switch for no. of cylinders, be sure it’s set right.
    #307989
    That’s a smart thought John. I bet it’s set to 8 cylinders.
