Turn signal switch
Home Forums Classifieds MGTD Kit Parts and other stuff Turn signal switch
  • #307161
    Kenneth Irvine, Jr
    @ken1946
    The turn signal switch I got has a larger offset than the original resulting in no clearance between the the lever and the wheel.  Does anyone have a work aroun to get more clearance.  Switch and column are supposedly out of a 1966 beetle.
    thanks…
    #307163
    Al Greig
    @al-greig
    I had the same problem.  I cut off the turn signal arm and drilled hole and threaded.  Took a length of 1/8″ threaded rod and bent to desired shape, covered it with a piece of fuel line and added a knob.  A bolt at connection point locks it in place so it won’t turn.
    https://tdreplica.com/wp-content/uploads/rtMedia/users/424/IMG_4241-800×1067.jpg?1597877902
    #307164
    Al Greig
    @al-greig
    #307165
    Anonymous
    Inactive
    PHILIP I have a ford powered mgtd for sale  you can reach me at 716  481 6152 or em at bkerlhgi@aol.com for more ifo thanks brian
    #307907
    Gregg Strain
    @greggs
    I’m probably way too late for a timely response. I had the same problem and purchased a VW Bus turn signal. It has a straight stalk. Plenty of clearance. Gregg
