Voltmeter Fitment
Home Forums MGTD Kit Cars VW Based Kits Voltmeter Fitment
  • #301408
    newkitman
    @newkitman
    While I was letting my tonneau cover dry after cleaning, I decided it was time to mount the voltmeter I got from MG magic. Harness was ready and I just needed to install the voltmeter. Well…..the voltmeter fits but I cannot tighten the mount nuts. Seems the voltmeter body outer diameter (including the face bezel) is just a tad bit smaller than the hole diameter. I can push the voltmeter through the hole in the dash with ease. My thought is to glue some veneer inside the hole to take up the space. Perhaps two layers. I think that’ll work. What do you folks think? Any better/easier ideas? I had thought of sheetmetal shims but I think the veneer idea will work better. Thanks in advance for your thoughts.
    #301409
    Toller
    @toller
    Are they VDO gauges? If so do they use a plastic ring or two threaded rods and a standoff aluminum bridge bracket for mounting. If the latter as you stated the hole in the dash is of a larger diameter than the bezel (2.2″) so putting some layers of veneer in the dash hole will not allow you to tighten the nuts on rods to sandwich the bezel of gauge/dash/mounting hardware. You may want to consider gluing/screwing a block drilled to same diameter as gauge body on inside of dash then mounting gauge to block and adjusting so bezel is proud of dash face similar to other gauges. By using this method it will minimize possibility of gauge being pushed through dash and shorting connectors on back of gauge. You still can use veneer to fill gap between dash hole and bezel diameter
    If it uses the plastic ring you will have to find a similar sized ring to tighten the gauge on a mounting bridge using a two locking ring configuration. On my gauges the threads were recessed on the locking ring and the gauge did not have threads on the entire depth of the gauge so I had to play around with different configurations to get it to mount. Would probably easier to draw a diagram than trying to describe the two options I have outlined. Maybe on next iteration of web soft we could see a drawing function to help illustrate a point
    David B Dixon
    Sabine
    #301411
    newkitman
    @newkitman
    Dave. Mine is a VDO gauge that secures to the dash with the two threaded rods and the aluminum bridge bracket you mentioned. I haven’t thought of using a wooden plug drilled out to fit the gauge. I could glue the plug into the dash and countersink three screws on the back side into the plug for extra security. Of course, whatever method I use, I still have to remove the dash to get a solid fix and not damage anything else. Thanks for the input.
    #301413
    billnparts
    @billnparts
    Don’t take this wrong, but how about getting a gauge to fit the hole?
    "Drive Happy"
    #301416
    newkitman
    @newkitman
    Bill. I did have one that fit but it was an amp gauge. I hate those things so ordered a voltage gauge from MG Magic that I thought would have fit the hole. But the hole diameter is just a tad bigger than 2 inch diameter.  🙁
    #301418
    Royal
    @royal
    If the hole truly is only a “tad” too big, how ’bout a big washer.  Get some heavy duty aluminum flashing from Lowes, and use an inexpensive hole saw to cut a hole exactly the size of your gauge.  Then using a slightly bigger (two “tads” bigger is good) hole saw, cut again to be left with a large flat washer which could be polished up (you might want to polish it before cutting) and would probably look OK.
    • This reply was modified 9 years, 7 months ago by Royal.
    #301445
    newkitman
    @newkitman
    Well I got a small piece of 1 inch thick mahogany from a friend of mine who milled it down to the thickness of the dash The using his drill press cut a 2-1/4 inch diameter plug. I glued and pressed in the plug (using a large rubber mallet) and let her dry this afternoon. Tomorrow I’ll drill out the hole for the gauge. A 2 inch diameter hole will allow the voltmeter to fit snugly. BTW the voltmeter is not a VDO gauge. Its a Dolphin gauge. Only real difference is the gauge needle is red rather than black.
