Home › Forums › MGTD Kit Cars › VW Based Kits › VW Gas Line Cleaning
- This topic has 4 replies, 4 voices, and was last updated 13 years, 6 months ago by
July 27, 2012 at 4:17 pm #234240
Hi gang,
Got any suggestions for cleaning a Type 1 gas line? (The steel line that runs through the tunnel.)The saga of my Duchess and the engine continues.The 1776 ran GREAT, for a while. Than started stuttering and stalling and now won’t start.Carbs are fine. Gas filter is new. Screen in fuel pump is clean as a whistle. But gas flow seems to be less than optimal and I suspect there might be some restricitons in the gasline.I do not have an air compressor, so blowing it out to see if it is clear isn’t really an option.Thanks.Paul Mossberg
July 27, 2012 at 4:32 pm #251222brake line power bleeder? Or maybe a turkey baster and a bit of hose?
Also, did you check the bit of fuel line that runs along the top of the transaxle? There was about a 6-inch length of hose on mine that just about disintegrated last year.
July 27, 2012 at 5:17 pm #251223I used PORs Marine Clean squirted into the fuel tube of my 74 Ghia. Let it sit for about an hour and then blew it out with my air compressor. As you don’t have an air compressor, perhaps use some carb cleaner with the power bleeder like Ed suggested. That sounds like it’ll work.
"If one thing matters, everything matters" - from the book The ShackJuly 27, 2012 at 8:04 pm #251224got a bicycle pump?
"Drive Happy"July 27, 2012 at 8:38 pm #251225Thanks guys. Good ideas.
Yes Ed, I’ve been all over the rubber bits.
I think the bicycle pump will win the day, at least for now.
Shoot some cleaner in from both ends, then tape the bike pump to the gas line.Paul Mossberg
