Which one is ground?
Home Forums General Discussion Which one is ground?
  • #234459
    Rick
    @rockyx
    I’m having some trouble with my wiring and want to make sure I have the fundamentals right.  Each turn signal has 3 wires coming out of it, 2 black, 1 red.  Anyone know which one is supposed to be the ground?
    Fancy picture below….
    rockyx2013-01-05 18:53:22
    #253745
    Gabor Kesseru
    @gkesseru
    Color coding is not always consistent. Ground connects to the shell of the bulb and the two hots each connect to one of the two contacts at the base of the bulb. Follow the wires, or check the continuity.
    #253746
    billnparts
    @billnparts
    One wire will be hot with the parking lights turned on. One wire will be hot with the turn signal activated(flashing). The remaining wire is your ground.
    (Sorry, couldn’t resist)
    "Drive Happy"
    #253747
    greg press
    @greg-press
    Just bought a circuit light for 3 dollars at home depot it should help
    #253748
    billnparts
    @billnparts
    Just noticed that a posting of mine is missing.
    Your bulb has two filaments, one of which burns brighter than the other. Just make sure the turn signal circuit activates the brighter filament.
    "Drive Happy"
