Home › Forums › General Discussion › window wings
- This topic has 10 replies, 8 voices, and was last updated 12 years, 1 month ago by
Gabor Kesseru.
October 18, 2012 at 11:55 am #234353
Today was a very interesting day.I accidently scracthed a window wing .I went to e street plastics on my computer found what i wanted 6 dollars for material 15 dollars for shipping what happened to if it fits it ships. Went to a home town hardware where my daughter lives when visiting, and asked do you have plexiglass.Yes what size do you want. He had many small sizes 2 ft x2ft 1ft x 1ft od shapes many thicknesses you name it ,it was there. Matched up old wing to a od shape .He said thats 3 bucks.Took it home roughed it in with saber saw finished it with a bench grinder an palm sander.Sometimes small hardwares are the best.
October 18, 2012 at 1:22 pm #252217
Greg .. I have several scratches on my wing indows.. I just consider that a patina and or provenance for the ol girl.jebarry2012-10-18 13:22:52
October 18, 2012 at 1:55 pm #252218Or just polish the scratches out with http://www.novuspolish.com/
October 18, 2012 at 2:40 pm #252219tried novus much to deep
October 18, 2012 at 7:05 pm #252220Anonymous
InactiveSome times Scratches can be sanded out with very fine sand paper 2000 grit or finer and polishing afterwards. Found a piece of plexiglass at local plastic supply store have enough to make 3 sets of wind wings. Store TAP Plastic. Watch when driling plastic can crack. When tighening bolts on plastic can crack plastic if to tight. Make sure bolt has clearance in plastic.
October 18, 2012 at 10:54 pm #252221GregAfter i sanded the edges of mine I took a blow torch to the edges to put a clear finnish on them.
TDREPLICA Map
October 3, 2013 at 8:36 pm #252222Anyone know the outside dimensions of the plastic wind wing panels?
Are they rectangular or are they wider at the top?October 3, 2013 at 8:47 pm #252223Ok, I found this one, would still like height dimension…
October 4, 2013 at 6:31 am #252224Widest 5.75″ longest 13″ vertical at windshield 12″. photo at 25751. should help with angles and radius. leaving for 23 days in China so not likely to respond till Oct 28.juneybug2013-10-04 06:43:12
October 4, 2013 at 7:11 am #252225Gabe, If you haven’t already decided on shape, I believe mine to be “stock”. I could trace them on graph paper and post which would give the shape and angles.
October 4, 2013 at 7:53 am #252226Thanks Juneybug and Roy. I can design one from that info.
Have a safe trip….. -
