Wiring – 12V generator
Home Forums MGTD Kit Cars VW Based Kits Wiring – 12V generator
  • #233959
    Donna Bryant
    @dkbryant
    I have begun to rewire with a universal harness that I
    purchased from Mid America Motorworks.
    The same one here:
    http://www.thesamba.com/vw/forum/viewtopic.php?
    t=148089&highlight=ignition+wiring
    I do have the 12V generator, so I am following the
    diagram at the bottom as far as the 10 gauge red wire, to
    the voltage regulator and then on to the starter. Do I
    also connect the 12 gauge red wire to the starter, as in
    the main diagram for the 6 volt regulator? Also, on the
    other end of the harness there is the 10 gauge red, 12
    gauge red and 12 gauge black wires – to be connected to
    the ignition switch. What wire to what position on the
    back of the ignition switch? There are 4 post St., Acc.,
    Bat, Ign. Any and all help is appreciated.
    #248965
    Donna Bryant
    @dkbryant
    Found the answers over at the Samba site. But stay tuned –
    I’m sure there will be more.
    #248966
    Go slow and use a tester.
