Re-built the engine last fall, but had a problem getting it to run well. Found out the electronic idle shut off didn’t work worth a hell of beans so replaced it with a non-electronic one and the engine runs great. Then just in th last month or so completely re-did the bakes and master cylinder now time to re-wire my TD because the previous owner wired everything in red, go figure. I plan on pulling the dash next week and replacing it along with all new gauges and plan to re-wire everything at once. By the way I found you can now use a GPS module in your cars and replace the Speedo with a electronic Speedo and get rid off the Speedo cable. the module can be placed anywhere in the car etc.
Any ideas on the best Harness/Loom to use.?
Also has any found any High Back pucket back seats for the TD’s with a VW pan? I have just the standard seat configuration and after a half day riding one gets TB/Tired Butt.
Thanks Mark
