Chevette valve system
Home Forums General Discussion Chevette valve system
  • #234061
    Pete Turner
    @chevtd
    I have a Classic Roadsters MGTD replica with 1.6L Chevette power. I am having a problem with the valve lifters. I also need a engine specific valve spring tool for this motor. The tool is GM valve spring tool
    #J-25477.  It looks more like a pair of plyers than a coventional valve spring tool.  Any one with info on such a tool or any knowledge of the Chevette valve and lifter system please contact me.
    Chevtd
    #249846
    Here ya go. $20 delivered.
    #249847
    Royal
    @royal
    Pretty sure that Advance Auto (and maybe all of the auto stores) will allow you to check out the valve spring compressor for free.  Sorry I can’t help with Chevettes.   Roy
    #249848
    ray10
    @ray10
    Intake valve should have 0.010 in.(0.25mm) clearance;exhaust valves should have 0.014 in (0.35 mm ) clearance.
    You might want to pick up a chevy chevette/pontiac t-1000 shop manual
    PMOSSBERG2012-03-28 14:01:11
    TDREPLICA Map
