Home › Forums › MGTD Kit Cars › My Project › dashboard
- This topic has 12 replies, 10 voices, and was last updated 10 years ago by
Bill Hartwick.
March 25, 2016 at 6:08 am #236060
I need to replace my dashboard. Can anyone tell me how thick it is? So I can buy the wood before I remove lt.
This topic was modified 9 years, 7 months ago by
Stephen Houser.
March 25, 2016 at 9:24 am #267576Anonymous
Inactive3/4 of an inch. Sometimes dash needs to be relived to install the gauges. Mark all positions of the electrical wires before removing gauges, makes it easier to install after dash is made..
March 25, 2016 at 9:31 am #267577My FF TDR mahogany dashboard was 5/8″ but I know it had been put through a thickness planer by PO as there was evidence of knife glazing that had not been sanded out. The black walnut that I used to replace it was planed to 7/8″ and I had to cut a rabbet to fit the speedo and tach
David B Dixon
SabineMarch 25, 2016 at 10:50 am #267578I bought a 3/4″ piece of solid oak when I did mine. After I cut the shape of the dash I then routered around the top where it screws onto the fiberglass so it didnt stick out to far. I didnt mark the guages since I was changing the look anyway. I also didnt mark the wireing since I was going to do a complete overhaul of the electrical system. My approach is less is more and keep it simple.
When youre ready to finish your dash remember to use plenty of sealer like spar varnish to protect from the elements. I dont know about you but as my daily driver Eliza Jane sees plenty of rainy days on the road.March 25, 2016 at 11:11 am #267579Another finishing product you may want to consider is Cetol. It is one of the few products available in Canada that is certified for external use and is oil based. I used it on skirt of hot tub for years My experience with spar varnish is that if surface is comprised and water gets into space between wood and varnish the varnish will turn white, blister and will have to be sanded down. With Cetol I just rough up with 0000 steel wool or 3M pad and apply another coat. I currently have three coats of a teak colour for depth and three coats of clear on both sides to protect the finish. It also has some UV inhibitors to prolong the life of the finish
David B Dixon
SabineMarch 25, 2016 at 11:32 am #267580Well, I am somewhat embarrassed. I would have preferred a large piece of solid walnut or mahogany, but could not find one large enough, even on eBay. I just used 7/16″ walnut plywood that I got from Home Depot online, and reinforced it on the back. I sealed it well and then put a 7/16″ plastic chrome strip on the top. I am happy with the appearance, especially since I am not a wood expert. The biggest problem with the plywood was that the veneer edges tended to chip, although I have hid them pretty well. I agree with Toller about the Cetol, because I just used urethane varnish and it was hard to work with and would have the problems he mentioned (blistering and turning white) if it got wet. Fortunately I live in Vegas, where its hot and dry and unlikely to get wet.
March 25, 2016 at 12:48 pm #267581Mine is solid burled oak planed to about 1/4 in thick.
Works great for the gauges and sits tight to the fiberglass so the welting looks right to me.The only thing I did was add a thicker piece of wood along the bottom to strengthen it and help with the steering column attachment.Used marine grade poly from Home Depot to finish it ( 2-3 coats I think ) and not touched it for 10-13 years.March 25, 2016 at 9:52 pm #267582Schu’s dashboard is nice, and after 13 years he can brag.
Bridget’s earlier dash was also 1/4 or 3/8 inch thick. When I replaced it I made the new one thicker to take screws along the edges for the glovebox door and the metal trim. The original TD dash was about 1/2-inch thick; I ended up at about 5/8.I will again argue for Pelucid + Minwax Helmsman Spar Urethane. Mine’s only a few years old but these tests show it should do every well for the long haul.edsnova2016-03-25 22:06:45
March 26, 2016 at 11:50 am #267583If I’m not mistaken, is the dash on a London Roadster part of the fiberglass body?
I thought about replacing mine until I took a closer look. I think the “wood” dash is either photo decal or very thin veneer.Amor Conquista Todo
March 27, 2016 at 5:50 pm #267584I think the dash is Formica – wood appearance ..
.I have looked behind the dash and it appears separateMarch 28, 2016 at 6:11 am #267585Thanks for all the info. Now I just need to deside on the wood. I have so cherry wood that was cut over twenty years ago, may use that.
March 28, 2016 at 6:35 am #267586Excellent choice on the cherry, I have an Allison where the dash is moulded right into the body with a thin wood looking laminate on top, took off the laminate and used cherry veneer plywood. It started as 1/2” but I planed it down to a 1/4”, came up really nice
March 29, 2016 at 4:09 am #267587Good, I have a friend with a planner, so l can take it down to the size that I need.
