directional light arm
Home › Forums › General Discussion › directional light arm
Viewing 18 posts - 1 through 18 (of 18 total)
  • #233048
    Dan Rosa
    @dan-r
     If you have read my last post you know I broke my blinker arm ,well i  fixed it, I had got it stuck in my shirt because it stuck out past the steering wheel  now I am not a big person 5.6 145 lb. so i figure  a person bigger than me must have the same trouble getting in and out of the car I shortened the stick so it is now behind the wheel not past it ,I also did away with the wiper switch on the stick moved it to the dash to the right of the head light switch only because I broke it in side the column  I think it came out better       Dan
    #241752
    Larry Murphy
    @larry-murphy
     Dan, My ts lever stuck out to far also. I cut it off using a tubing cutter while holding it with vice grips to support it. I pulled the plastic knob off the metal stick only to find that the stick had two small fins that matched up with slots in the knob to keep it from slipping .I drilled a small hole in the side of the knob and put a set screw in that faces toward the dash so it is not noticable. It not only looks better ,it works better too.
    #241753
    Mark Hendrickson
    @pink-mg
    You guys are brilliant…I would have installed a larger diameter steering wheel
    #241754
    Larry Murphy
    @larry-murphy
     Pink MG ,, I told you we needed you expertice. Now do you see why?LOL   Two of us have little stubby turn signal levers when we could have had nice big wheels instead. Once again I took the cheap route.
     Seriously ,I thought about it but would have had to raise the steering column to clear my legs and then the top of the wheel would have been too high to see over. I had a 15” modified Datson wheel that I had flattened on the VW based car I sold that was just right for that car  but it had more room between the seat bottom and the steering wheel.
    #241755
    Mark Hendrickson
    @pink-mg
    My plans for the car were indeed raising the steering column…my legs were trapped with the way it was. That’s why it was disconnected from it’s mounts when delivered.
    #241756
    Mark and Larry, don’t be dissin’ that Big Wheel look! It looks more authentic, plus it promotes slimness in the hips and buttocks.
    That said, I have a future sister in law who is rather substantially constructed, and she wedged herself behind Bridget’s wheel in less time than it took for me to say “sorry about the tight squeeze.” It all depends upon one’s motivation, I say.
    Now, where can I get one of them long stalk bus turn signal doohickies…?
    #241757
    Dan Rosa
    @dan-r
     Well ,,,now  that the stick is behind the wheel doe’s that make the wheel bigger ? it looks bigger  Larry,,, now that i did that, i will make a new stick end out of wood to match the rest of the knobs on the dash but i will just glue it. Mark would a tilt wheel work ?  if you could find one ,,I don’t think it would too hard to put in……..Dan
    #241758
    Larry Murphy
    @larry-murphy
     Ed ,  I love your wheel, It’s just that I could never enjoy it because my wife could never find out how much they cost and secrets are hard to keep.
      Dan ,I think a tilt column could be fitted and would be nice when getting in and out,however after looking at the diagrams in the Chev. manual and seeing  what all is crammed [ carefully positioned ] into the Chevette column, I think Court Wizard had the right idea when he replaced his steering column with a simpler and more authentic one.
    #241759
    Funny how easy this stuff is when you have an actual assembly manuals. Classic Roadsters’ manual includes specific directions on cutting and straightening the Beetle turn signal stalk to keep it away from the flat steering wheel and within the 15″ diameter.
    #241760
    BCW manual says to gently heat it and bend it back–a dubious proposition at best. Mine’s all lumped up with epoxy, as are several others I’ve had a peek at.
    #241761
    Sorry Ed, but the BCW manual was right. As (of course!) was the Classic Roadsters’ manual.
    You cut the lever at the bend nearest the end. And you gentle heat the lever near the column and straighten it out. All you need is a hand held propane torch. Gentle heat, gentle pressure on the lever. Works like a charm.
    #241762
    Dan Rosa
    @dan-r
     I think,, FIRE and plastic just don’t mix well i think i would remove the lever first    Dan
    #241763
    The dude who built Bridget seems to have done a pretty fair job of it. I doubt I’d have done better. But nobody’s perfect. Looks like he cut the lever and glued it back on backwards. Not beautiful but works well enough. I may end up going with a Bus signal someday tho.
    #241764
    Larry Murphy
    @larry-murphy
     London Roadster  went a different route with the signal lever in their factory built cars. They cut the lever at the bend closest to the column and then slipped a piece of tubing that was flattened just enough to fit the end of the shortened lever and was held in place by a very small bolt [screw] that went through a hole in the tubing  and the lever.They added a small knob to the end of the tube . The entire assembly was made of chrome plated parts and looks nice.
     My second LR car had the steering column replaced by the PO . He used a dished wheel to miss the lever. When I put a flat wheel on it ,I cut the lever in the first curve and used the top from a ballpoint pen to extend it to the correct length. It was nice and shiney,worked well and of course it was cheap.
    #241765
    Um, not plastic. At least the turn signal in my ’71 Beetle donor car is not plastic.
    #241766
    Larry, that sounds very cool. I’m picturing a Cross sterling (pen) for the signal lever. Do you remember what you used?
    #241767
    Larry Murphy
    @larry-murphy
     Ed,  I do not remember what brand the pen was.It was in a cup sitting on the kitchen counter.I think it was a giveaway advertising something. The top was removeable and just happened to be the right length and diameter to fit the shortened lever.
     If you don’t find a suitable pen ,try a piece of tubing from a home improvement store you could plug the end with a rubber plug or a plastic cap, or possibly with a small cabinet knob.
     Just look around ,the possibilities are almost endless.
    #241768
    Thanks for the inspiration, man.
