Home › Forums › MGTD Kit Cars › VW Based Kits › Disc Brake Conversion – Ball Joint Replac
- This topic has 5 replies, 3 voices, and was last updated 17 years, 2 months ago by
Pat Dwyer.
January 11, 2009 at 12:07 pm #232508
Hope everyone had a good holiday!
When changing from drums to discs on the front end does it increase wheel width?
I am replacing the hacked up front beam with a new adjustable beam and was planning on installing discs at the same time.
I was also wondering if anyone had any advice on replacing ball joints. I have heard that there was a problem with replacement ball joint sizes not being correct.
Thanks.
January 12, 2009 at 11:28 pm #238088Evening,
I have installed the adjustable front axle and disc brakes without a problem. Be sure to read “PinkMG” on the proceedure.
However the ball joints are another situation. I installed the Brazillion made and the German made with the same results, a very still steering that isn’t getting any better even though I have put about 2000 miles on the car since I installed the German made ball joints. The parts place and this Form has said with wear they will become looser.
I installed the “EMPI” style wheels also.
Mr. Bill
January 13, 2009 at 2:08 pm #238089I bought trailing arms that already had German ball joints installed. It was cheaper than buying the joint and paying the local shop to press them in. At the time, I didn’t have access to a decent press.
Don’t use Brazilian ball joints.
The disc brake conversion doesn’t affect the width (track) enough to worry, maybe 1/4″ or less.
January 13, 2009 at 3:17 pm #238090Thanks for the info guys.
Mark,
Did you have any problem with the torsion arms that had the ball joints already installed? Where did you find them with German ball joints already installed?
Pat
January 14, 2009 at 11:01 am #238091Hi Pat,
I got them at a place called CIP (California Import Parts) if I recall correctly. I had no problems at all. They sure made life easier too.
January 14, 2009 at 2:32 pm #238092Thanks Mark. That where I bought my new beam.
Aircooled.net has all four torsion arms w/ball joints for $180.00. I thought that was pretty reasonable. Don’t know what brand ball joints they use though. I am like you and would want German ball joints.
