Fiberfab Ford based MG TD owner
Home Forums Picture Gallery TD Replicas Fiberfab Ford based MG TD owner
  • #232972
    Tom Barbeau
    @nigelshiftright
    I have a Ford based TD I’ve owned for the last 10 years.  I need a new speedometer cable and i can’t find a reference.  I bought a Pinto cable but it doesn’t match.  Is this a VW Ford Hybrid?
    #241272
    Steve Crites
    @ringo
    Welcome to the group!
    Sorry, I have an electric speedo so I don’t know any part numbers. However, you might check with the manufacturer of the gauge.  They may require something defferent than the stock Pinto cable.
    Ringo
    #241273
    James Cochran
    @jascochran
    My baby is dismantled right now. I can pull my cable out and measure it for you if that would help.
    #241274
    Scott A Chynoweth
    @1oldbuzz
    Just about all the major parts stores carry a universal cable.Just cut to the needed length,comes with the crimp on end and little tool to do the crimping.Best way to cut is with a cut off wheel on a dremel tool.
    #241275
    billnparts
    @billnparts
    Early Fprd Mustangs had a screw on end at the speedo. You will find the ’67 model with manual trans has the longest length and will accomodate the speedo gear required.
    "Drive Happy"
