Home › Forums › General Discussion › Finished my 1952r ff
- This topic has 44 replies, 15 voices, and was last updated 10 years, 3 months ago by
john barry.
December 9, 2015 at 10:17 am #266460
GREAT job!
Amor Conquista Todo
December 9, 2015 at 11:36 am #266461No I didn’t repaint car that is the orginal clear coat.car was almost pink and had bubbles in paint and faded allover.I water sanded car with 5 different grades of sand paper.finishing up with 3000grit .that took 3 weeks everyday for about 5 hrs a day.then 4 days of buffing out paint.and eND results was better and cheaper than a repaint.plus it is original factory clear coat.
December 9, 2015 at 11:37 am #266462That paint job is approximately 40 yrs old
December 9, 2015 at 2:38 pm #266463Any chance of seeing pics of dash and upholstery on doors
David B Dixon
SabineDecember 9, 2015 at 2:57 pm #266464yea I am going to take it out clean it Saturday and I will take pics of inside with top down so the new carpet can be seen
December 9, 2015 at 4:56 pm #266465Paint? Or Gel Coat?
December 9, 2015 at 6:29 pm #266466It’s gel coat bin
December 9, 2015 at 6:36 pm #266467Didn’t mean to say bin sorry
December 9, 2015 at 7:46 pm #266468Very, very nice.
"Drive Happy"December 10, 2015 at 9:26 am #266469Great work! And proof that you can bring gel coat back from the dead!
December 10, 2015 at 11:54 am #266470With a ton of work it sounds like – but looks great
December 10, 2015 at 12:06 pm #266471It’s alot of work bringing gel coat back from the dead but it’s worth it as long as you don’t have chips or deep scratch that go all the way down to the fiber glass.if you take your time use emery cloth .I started out with 700 grit then 1000.then 1500 then 2500.finished with 3000 grit.then buffed it with number mirrow glaze number1.finished it with number 2.then waxed with a really good wax. Make sure you soak emery cloth in water for about an hour before you start sanding and keep it wet while you sand.
December 10, 2015 at 2:48 pm #266472Joe. Did you disassemble/remove the fenders before sanding and buffing?
"If one thing matters, everything matters" - from the book The ShackDecember 10, 2015 at 4:43 pm #266473No I didn’t all sanding was done by hand and the buffing was done with a button buffer.places I could not net with the buffer I buff by hand.the buffing process is a real job.in some areas I had to buff redan it and buff .alot of buffing until u get the desired result.it takes alot of time and patients
December 10, 2015 at 5:48 pm #266474I found a picture of Joe’s arms… Before… and After all that hand sanding and buffing:
PMOSSBERG2015-12-10 17:50:14
December 10, 2015 at 6:25 pm #266475I wish
December 10, 2015 at 8:34 pm #266476Little circles, big circles.
December 10, 2015 at 8:54 pm #266477Yep uh hu
December 11, 2015 at 12:44 am #266478Mr Miagi…
Slowly coming back from the ashes...December 11, 2015 at 12:17 pm #266479wipe on, wipe off
