fuel pump
Home › Forums › General Discussion › fuel pump
  • #234063
    greg press
    @greg-press
    If i remember right the way you deside which fuel pump your car uses is weather it has a generator  or alternator.If your car has a generator the fuel pump is taller is tnis correct.
    #249855
    newkitman
    @newkitman
    Sort of. It’s more if you have a generator the pump stands straight up. If you have an alternator, because the rear end of the alternator is larger diameter, you need the pump that leans (tilts) back to allow room for the alternator. ALSO…the fuel pump shaft for an alternator is about a 1/4 inch shorter. Wrong shaft is not good.
    #249856
    Dan Rosa
    @dan-r
     Hay guys why don’t you just go to an electric pump ?? quick and simple Dan.
    #249857
    greg press
    @greg-press
    Today i got my car back with a new fuel pump in it.It runs great. The only thing it does now is a little backfiring not bad. It did it a little last year then it quit hopefully the same this year we will see. 50 degrees in buffalo ny put on winter clothes and went for a ride 70 degrees forcast for monday out for coffee my wife seems excited and so am i.
