Home › Forums › General Discussion › Loose door hinge screw
- This topic has 10 replies, 8 voices, and was last updated 13 years ago by
Steve Crites.
March 25, 2013 at 9:12 am #234590
The top screw on the driver’s side top door hinge is loose and will not tighten on my older FF kit. This is likely THE most stressed of the door hinges because of both the frequent use and the top location.
Has anyone else experienced this? How did you resolve it? Can you get access to the backside of this screw in the body tub? Any suggestions?I can’t find a pic of that area in the assembly manual, and before I try to carefully remove the carpet to explore, I thought I’d ask. Searching here didn’t turn up anything…
KentT 2013-03-25 09:12:48 Early FF TDr on 69 VW pan
Slowly coming back from the ashes...March 25, 2013 at 11:15 am #255216I have a Classic Roadsters Duchess, not an FF…but…
There are access holes behind the side panels on a Duchess.I have to assume there is an access hole behind your side panels or carpet.There’d be no other way to tighten the bolts down.PMOSSBERG2013-03-25 11:16:02
March 25, 2013 at 11:19 am #255217Anonymous
InactiveKent: Fastener can be reached with a long extension from the wheelwell. Also under the carpet there may be a acess hole to reach the fastener.
March 25, 2013 at 1:50 pm #255218Thanks, guys. I’ll try George’s suggestion on accessing it through the wheelwell when it warms up a bit. I’m trying to avoid ripping out the carpet to look for access from the inside, if possible.
Slowly coming back from the ashes...March 25, 2013 at 2:17 pm #255219George,
Just curious, ’cause I like to learn as much as I can about each of the TD replica variants.There is a fairly large body panel between the rear fender openings and the rear door jamb. Is that space completely open on a Fiberfab?There is no way to reach into that body cavity on a Duchess.Paul Mossberg
March 25, 2013 at 2:21 pm #255220Kent,
Wheelwell on mine as well unless of course you are loose on the door side.Most likely they will be rusted up inside there and hard to tighten up ( may just break ). I ended up replacing all the fasteners in my car w/ SS for my son in the future or whoever owns many years to come.March 25, 2013 at 2:38 pm #255221Yes, the Fiberfab kit has a gap in the wheelwell between the outside body and the inner tub. The assembly manual has you cut access holes for the hinge bolts into the tub, but that is not necessary.
If it has a tendency to loosen up, then put some loctite on the threads when you reassemble and/or opt out for a locking nut.Bill Ascheman
"Drive Happy"March 25, 2013 at 3:58 pm #255222I bought barrel nuts and glassed them in place on the hinge screws, the latch strike plate and on the nuts that hold the hood side panels in place. Also using all stainless for the screws. These are the places that will be hard to reach once everything is together. Should never go bad.
March 25, 2013 at 4:51 pm #255223When I put my MiGi together, I didn’t use nuts but rather a small piece of steel channel which I tapped to fit the hinge screws, there are 2 screws per hinge. Once the screws are started, it is not necessary to access channel to tighten screws. Set channel in some silicone to hold in place but also allow future removal if required.
March 25, 2013 at 6:56 pm #255224The VWs used a threaded plate inside the door jamb, similar to what you described Al. Sadly, unless I can access the backside from inside the tub, I’m not sure I can come up with a “permanent” fix. It’s been too cold to work in my carport today, with snow flurries all day long — I don’t have a garage, much less a heated one…
KentT2013-03-25 18:59:16
Slowly coming back from the ashes...March 25, 2013 at 9:35 pm #255225When using stainless fittings be sure to use anti-sieze (available at any auto store) on the bolt and nut or it will weld itself together down the road and you will never get it loose. Ask me how I know……:?
