Home › Forums › MGTD Kit Cars › VW Based Kits › Oil Pressure
- This topic has 3 replies, 3 voices, and was last updated 20 years, 5 months ago by
Brian LeBlanc.
September 29, 2005 at 9:19 pm #232172
Wondering if this is a concern. My oil pressure during start up it 40+ PSI, but after warmup at idle it dips below 10 psi. a few revs and up if goes. Any suggestions other than increasing my idle speed which is at about 900 rpm.
September 30, 2005 at 8:38 am #236661Many things can contribute to this. The 900 RPM idle speed is on the top end of a fast idle speed in my opinion. The idle speed affects the fan speed and engine cooling. Too low is not good either.
Oil viscosity is also a concern, most Type 1 engines like 20W-50. In the dead cold of winter in Calgary, 10W-40 is a safe bet. Do you drive the car when it’s that cold? Do you use a block heater?
If the motor has a lot of miles on it or was not given regular oil changes before you got it, the oil pump may be on the edge of it’s clearances or gummed up. At speed, the pressure stays great, but at idle there is too much clearance to make good pressure. Do you use a remote filter w/o a high volume oil pump, or a bone stock set-up? Do you have an aftermarket deep sump?
How you check your oil is important too. Don’t let it sit for a long time to let the oil settle before checking it. After the engine is warmed up, shut it off and check it right away. Bring it up to the full level if it isn’t there.
Worst case is a bearing/s that is/are going south, but you would hear that most of the time at idle.
These Type 1 motors can be modified for “Full-Flow” oiling easily. Add a high volume oil pump and a remote filter too. Most every performance Type 1 has this modification, but it a good thing for stock motors too. A deep sump is also a good addition and would not require engine disassembly like the “Full-Flow” oiling mod would (you have to drill and tap pipe threads in the block).
These things are air cooled and depend on oil for cooling, even more than a water cooled engine does.
If I knew more about you engine, I could suggest a better reason for the low idle/low oil pressure. Try the simple stuff first.
September 30, 2005 at 8:41 am #236662Brian,
Because you car has an Air Cooled VW motor, it is normal to have a higher oil pressure at first when the engine and oil are cool. As the engine heats up, so dose the oil and the warmer the oil, the thinner it becomes thus, a lower oil pressure. That being said, long idle times, more than 10 min, in a air-cooled car isn?t a good idea. On your next oil change, I suggest not only draining the oil from the center plug in the pan, but remove and inspect the oil screen in the bottom of the oil pan. Make sure there is no debris clogging it and if it is damaged or brittle, replace it.
My .02 worth hope this helps
October 1, 2005 at 12:20 am #236663I have a 67~68 1500. I am running with 20W50, today I got a new oil presure sensor, that has two leads so I will add an idiot light as well, so that if the gauge is off, I know I’m ok if the light is not on.
As far as driving the car in Calgary, I expect to garage it for 6 months starting at the end of October, or when the snow flies! I get concerned that the figerglass body may crack it it gets too cold, and they drop gravel when it gets icy. -No block heater. I guess I will find out soon if it is the oil pump or just a tired gauge!
Thanks for your advice.
- The topic ‘Oil Pressure’ is closed to new replies.
