Home › Forums › Picture Gallery › TD Replicas › our new mg
- This topic has 12 replies, 8 voices, and was last updated 16 years, 9 months ago by
Greg Stickney.
June 8, 2009 at 2:02 pm #232644
June 8, 2009 at 2:20 pm #239042Nice toy.
Where are you and can you provide any details that would be great. I like red too.
June 8, 2009 at 2:52 pm #239043Looks nice an except for the white interior a match for mine. Tell me more about it.
June 8, 2009 at 6:26 pm #239044Sweet. Enjoy the ride!
June 8, 2009 at 9:35 pm #239045Nice, enjoy her, what is she powered by?? &n bsp; &n bsp; &n bsp; DanR.
June 9, 2009 at 12:03 am #239046Great auto, a real head turner
. Sharp!June 9, 2009 at 7:26 am #239047Very nice!
We have quite a collection of Italian Red FF Replicas going. Enjoy the Ride!
Rich
June 9, 2009 at 1:48 pm #239048Do you use a UV protective finish for the red gelcoat? My car is white, so fading is not an issue, but I do use a marine finish with UV protection. I have seen the red gelcoat fade out in the sunlight on both cars and boats.
. My seats are burgundy and a real backside burner in the sun. My other sportscar convertible has black interior and it’s torture, I like the white interior
June 9, 2009 at 3:30 pm #239049Welcome and nice ride! Happy Motoring
June 9, 2009 at 5:13 pm #239050The car is powered by a ford engine, 2.3L, .030 over bore, 10.5 to 1 pistons, high lift cam, holley four barrel, and a four speed. 175 horse documented on a dyno. Currently we are rewiring the car because of the miserable condition of the wiring. The car runs, but thats about all.
I have ordered a new harness custom made for the car, but using the GM standards instead of fords. We are in Florida, and loving it.
Greg
June 10, 2009 at 9:48 am #239051Sounds like a healthy engine, hope your brakes are as well. I have to stand on my brakes to get them to slow the car 🙂
June 11, 2009 at 12:08 pm #239052Bigger brakes is not a bad idea. Luckily there are many larger front brake upgrades available to fit the Pinto spindles. My 1940 Ford uses the Pinto spindles, 11″ Ford Granada/Lincoln Versailles rotors and ’78-83 GM “G” body metric calipers (Monte Carlo, Regal, Cutlass, Grand Prix).
If you are using the little 6.75″ rear in the car, that’s another weak link. Unless the donor rear came from a V6 powered or station wagon Pinto/Mustang II. If it did, it’s an 8″ Ford rear and is beefy enough for the higher horsepower.
These rears are known as “baby 9 inch’s” and many parts are available for them too. I also use this rear (from a ’74 Maverick) in my 40 Ford. It has an Eaton-Detroit Trutrac Posi, 3.80:1 Richomond gears and a disc brake converison kit that uses the same GM “G” body calipers as the front. My disc parking brake is mounted to the pinion yoke on the rear. The rotors are also 11″ from a Lincoln MkVII.
Of course all of these mods require the use of a 5 lug wheel that uses the 5×4.5″ Ford bolt pattern. Some vendors offer the GM 5×4.75″ bolt pattern too.
OEM Pinto/Mustang II front disc are 9″ and rear are lame drum brakes.
Centech, Ron Francis, Painless, American Autowire all offer great harnesses for these cars. Basically you just need to order how many circuits you want. Most are made to accomodate the GM steering columns, but I’m sure Centech or Ron Francis will make whatever you want…just bring $$.
June 11, 2009 at 1:34 pm #239053I used American Auto Wire, the Hwy 15 unit. It has more than enough circuits for this tiny car.
Greg
