Home › Forums › General Discussion › Pitting tip
- This topic has 4 replies, 4 voices, and was last updated 15 years, 8 months ago by
July 23, 2010 at 5:16 pm #233057
Brought Mrs. Peel home yesterday, finally she is permanetly in my garage.
A friend who is a boat guy gave me a tip to remove pitting from the chrome(on her overriders). Treated them with 3M marine metal polish and restorer. Them rubbed them down with aluminum foil and finally retreated them with the 3M.
They came out great and saved me the cost of new overriders.
Thought I would pass the tip on.
Monday I will order the wire wheels
July 23, 2010 at 5:55 pm #241812Good tip!
But be aware that the metal polish is just that, a polish, and you will still need to wax the parts to protect them and keep the pitting from coming back even quicker.
July 23, 2010 at 6:18 pm #241813I had heard of using aluminum foil but have not tried it. I’m guessing that the foil is softer than the chrome finish so it cuts the rust or pitting without being too hard on the chrome. Did you use good quality ,heavy duty foil or the cheaper store brand? Also I’M assuming that you crumple it up to form a ball much like a steel wool pad. Does the marine polish then polish out the fine scratches left by the foil?
I’ve tried just using chrome or metal polish with minimal results and lots of hard rubbing.
July 23, 2010 at 10:46 pm #241814Larry Murphy wrote:I had heard of using aluminum foil but have not tried it. I’m guessing that the foil is softer than the chrome finish so it cuts the rust or pitting without being too hard on the chrome. Did you use good quality ,heavy duty foil or the cheaper store brand? Also I’M assuming that you crumple it up to form a ball much like a steel wool pad. Does the marine polish then polish out the fine scratches left by the foil?
I used the heavy commercial grade I bought at Sam’s Club. The Marine polish takes out most of the exisitng scratches and anything from the foil.
Gonna wax them tomorrow
July 24, 2010 at 9:38 pm #241815This sounds like a great tip. Will give it a try. Thanks!
