Home › Forums › General Discussion › Small scratches in chrome
- This topic has 12 replies, 8 voices, and was last updated 11 years, 2 months ago by
Montie Henderson.
November 29, 2014 at 12:03 pm #235483
The prior owner of my TDr used what was apparently a dirty buffing pad to polish some of the chrome. It left small swirls and scratches.
Do any of you have a “magic” trick to remove them. I have tried many polishes but no joy.
November 29, 2014 at 12:46 pm #262282Roy, have you used jeweler’s rouge (or polishing rouge)? You can get it in sticks at Harbor Freight and Lowes. It comes in various forms (grits) depending on how aggressive you want to be. I’ve used it to polish aluminum and stainless steel parts on my Cobra build. I also used it to polish out a scratch I had in my steering wheel spoke. I used a 4″ cloth polishing wheel I got from Harbor Frt. that is mounted on a bench grinder, but you could mount it on a drill motor as well. Good luck.
November 29, 2014 at 2:35 pm #262283Would that jewler’s rouge work on a sheet of stainless steel to make it shine like chrome?
"If one thing matters, everything matters" - from the book The ShackNovember 29, 2014 at 5:50 pm #262284Roy,
This might be what you’re looking for:
http://www.amazon.com/Green-Rouge-Polishing-Buffing-Compound/dp/B003K7U0J6
(It’s also the ideal material to use on a leather strop to hone knife edges.)
If the scratches are fine enough, you might be surprised to find that toothpaste will do the job.
-Dave
November 29, 2014 at 6:12 pm #262285Allen, yes it will, but if it is a big piece of SS, it will take a lot of buffing. I have polished several pieces of SS using this method.
November 29, 2014 at 6:32 pm #262286Thanks Sam. I’ll prep my shoulders and elbows. I’m making three pair windshield cowl brackets out of 18 gauge ss on a 24-inch by 24-inch sheet.
"If one thing matters, everything matters" - from the book The ShackNovember 30, 2014 at 11:41 am #262287Allen, save your shoulds and elbows, you’ll need a powered 4″ or 6″ cloth polishing disk.
November 30, 2014 at 1:54 pm #262288Well I do have an electric buffer. Would that work?
"If one thing matters, everything matters" - from the book The ShackNovember 30, 2014 at 7:43 pm #262289Allen, it might. Give it a try. As I mentioned above, I used a 4″ or 6″ cloth polishing disk mounted on one side of a grinder motor. The metal ( alum or SS) will get warm during the polishing process due to the pressure and the friction so I think you’ll need the power and speed of the motor to get good results. Also, wear gloves to hold on to the metal as it will get pretty warm.
December 1, 2014 at 1:29 pm #262290Anonymous
InactiveMight try a piece of aluminum foil . It surprisingly will remove rust from a chrome bumper . A piece is rubbed over the area and it cleans area. I have tried it and it works. I don’t know why.
December 1, 2014 at 4:47 pm #262291I to have used tin foil and it does work . The more expensive foil seems to work better . However its a temp. fix.
December 1, 2014 at 6:49 pm #262292I’ve heard of folks having great success removing rust with the aluminum foil method.
But let’s remember Roy’s question which started this thread, and that was how does one remove swirl marks and fine scratches from chrome?
December 1, 2014 at 8:13 pm #262293Aluminum foil or a brillo pad, even fine steel wool works for removing rust. I don’t think it will do much for scratches though, might even make it worse.
