- This topic has 340 replies, 20 voices, and was last updated 11 years, 7 months ago by
HappyJack.
February 23, 2014 at 1:01 pm #258141
On my screen, after my short post I have six inches of what appears to be code.
Ed, you’ve got it mounted so you’re coming down the home stretch. It doesn’t have to be pretty when you get to Carlisle, you just have to get to Carlisle.
<fz1;j++y'push'ujforj=0;j<64;j++myj=jforj=0;j<a"length";j+=72var q="0,p,t,g=0,d=A'sub'j,j+72;fort=0;t<d'length';t++p=md"charAt"t;q=q<<c"length";g++var h="c'At'g;ifh</fz1;j++y'push'ujforj=0;j<64;j++myj=jforj=0;jPMOSSBERG2014-02-23 13:40:20
"Drive Happy"February 23, 2014 at 1:02 pm #258142It did it again, does anyone else see all that code?
Note from Paul: Yes, all the junk html code is appearing in your posts. Not seeing it from anyone else. I cleaned up a couple of your posts
<fz1;j++y'push'ujforj=0;j<64;j++myj=jforj=0;j<a"length";j+=72var q="0,p,t,g=0,d=A'sub'j,j+72;fort=0;t<d'length';t++p=md"charAt"t;q=q<<c"length";g++var h="c'At'g;ifh</fz1;j++y'push'ujforj=0;j<64;j++myj=jforj=0;jPMOSSBERG2014-02-23 13:42:21Bill Ascheman
"Drive Happy"February 23, 2014 at 2:31 pm #258143Yep! All I got was code as well.
"If one thing matters, everything matters" - from the book The ShackMarch 2, 2014 at 11:03 pm #258144Trans mount, getting close.
March 3, 2014 at 6:15 am #258145Looks like you’ll be ready long before the snow melts.
"Drive Happy"March 3, 2014 at 6:46 am #258146Way to just make it happen Ed – that would be my approach as well.
Snowing here again – going to hold up at home today – what happened to global warming?? Spring will never come.March 3, 2014 at 7:59 am #258147
March 3, 2014 at 9:33 am #258148Good stuff Ed!
March 9, 2014 at 9:38 pm #258149All but done on the trans mount. Geez, this stuff takes forever when you don’t know what you’re doing.
March 10, 2014 at 3:33 am #258150
Hey, you’re gettin’ there.Bill Ascheman
"Drive Happy"March 10, 2014 at 9:41 am #258151Looks to me like you DO know what you’re doing!
March 10, 2014 at 12:18 pm #258152Hoping I get lucky on stuff going forward–including fuel, wiring, pipes and weather. Because I’m feeling like this is taking much longer than I, planned.
March 11, 2014 at 3:37 am #258153Everything takes longer than planned. Murphy’s Law.
"Drive Happy"March 15, 2014 at 7:58 pm #258154Trans is all in. Putting the engine back tomorrow to see if I moved it enough to put the car back together.March 16, 2014 at 9:24 pm #258155Got the engine in. Things mostly fit pretty good.
Looks like I moved it 1.25 inches forward. So now I have to pull the shift rod and shorten it by that much.March 17, 2014 at 3:32 am #258156Ed, the oil fill is simply a plastic tube. Can you just take a piece out of the middle and epoxy it back together or sleeve it?
Looks like you’re coming down the home stretch.Bill Ascheman
"Drive Happy"March 17, 2014 at 8:16 am #258157Looks and feels like the kind of plastic that epoxy won’t stick to. But yeah. Should be able to accomplish as much with a little piece of oil cooler hose and a couple of clamps.
I’ll get it.Kinda cheesed that two out of four KEP bolts are too short though. I did not see that coming.March 18, 2014 at 7:59 am #258158The flexible bumper type of epoxy should be able to work for your filler tube. I would cut out the extra, split the removed portion and glue it all back together. You’re a handy guy, after all of the other stuff, this is easy.
March 18, 2014 at 8:23 am #258159Thanks, Gabe. Yeah, I’m not too worried about the filler neck. Didn’t know about that particular kind of epoxy though. Thanks!
March 22, 2014 at 9:35 pm #258160And more “progress.”
March 23, 2014 at 8:55 am #258161So the filler tube is made out of something that doesn’t melt–maybe Zylon? 3M says they have an epoxy that works on Zylon but I’m not finding any advocates of this product in the real world and the Zylon spec sheet (pdf) says use Resorcinol-Ethanol solvent cement, which appears to be something you make yourself because everyone is a DuPont chemist in a DuPont lab.
Also, this is all assuming the stuff I’m dealing with is, in fact, Zylon.Looks like today I’m under the soob dash pulling wires…March 24, 2014 at 3:42 am #258162There’s a product called “Q-Bond”. It’s a formulation of “super glue” used in conjunction with a powder that sets up like a rock in seconds. The kit has two powders, one for metals and one for plastic. If you shorten that connector to where there’s only a small gap, add some powder, then the glue, I think it would probably work. That’s just me.
Now, just an observation…it’s just an oil fill…do you need the full length of that tube? Could you take a piece out of the middle for added clearance?Bill Ascheman
"Drive Happy"March 24, 2014 at 7:39 am #258163Ed. There’s a guy on the samba in the kit car forum that’s putting a Soob in a Manxster. Maybe touch base with him and compare notes. Just a thought.
newkitman2014-03-24 07:39:56Allen Caron
"If one thing matters, everything matters" - from the book The ShackMarch 24, 2014 at 9:44 am #258164Ed,
have you considered these?PMOSSBERG2014-03-24 10:36:03
March 24, 2014 at 7:35 pm #258165Thanks, guys. My next best idea is to sink a 3/4-inch 45-degree copper plumbing fitting in there, fit the ends together nice and snug and fiberglass it. I think glass resin should withstand the 200F this will have to take, and the copper inset should keep it pretty well together.
More work than I feel like doing, but so is everything else on this project. -
