Home › Forums › MGTD Kit Cars › VW Based Kits › Taillight Wire Routing
- This topic has 11 replies, 6 voices, and was last updated 9 years, 1 month ago by
newkitman.
February 15, 2017 at 7:24 pm #302995
I tried this in the Search Engine and came up empty. Where do you folks route the taillight wires? Thought an extra hole in the fender to tub mount? Along the splash pan horizontal mount? Could ask the same for the front parking lights but I have one extra smaller hole to run the wires to the park/turn signal lights. Thanks all.
"If one thing matters, everything matters" - from the book The ShackFebruary 16, 2017 at 12:18 pm #303007Classic Roadsters Ltd provided a rear harness, that runs through the lower body tub, exiting into the engine compartment. From there, the taillight wiring runs through a small hole through the side wall into the rear fender well. I can take a couple pictures if that would help.
February 16, 2017 at 2:31 pm #303013I posted this three years ago when I was working on that stage of my TDr:
“IMHO:A basic problem on my FF was that both front and rear lights wiring ran loose and unprotected on the underside of the fenders to the connection point with the lights. I decided that this was a potential problem because the connections could vibrate loose or in the event of a tire tread loss the wiring might be ripped off, compounding your problems.I used some semi-rigid plastic tubing to arc the wires up under the fender and away from the tires (tyres?) as much as possible. It’s probably also good to allow a small slack loop so you can lift up the light assemblies for service.Just my 2 cents.”
I believe that someone also posted that one TDr manufacturer had moulded-in channels on the inside of the fender to route and protect the wires.
No photos at this time but I will take some if anyone is interested. 🙂
This reply was modified 9 years, 1 month ago by
Rich Kallenberger.
February 16, 2017 at 5:25 pm #303016Paul. That is how the harness I made is run; out the body tub into the engine compartment and along the rear valance horizontal mount, then to the fender well. Like Kall, I’m nervous about the wires being near the spinning tire. I was thinking of glassing in the wires to protect them as I think the tail light wires may be far enough from the tire. I’ll check tomorrow.
Thanks you guys.
"If one thing matters, everything matters" - from the book The ShackFebruary 16, 2017 at 6:13 pm #303017Original routing of wiring on my FF was electrical tape about every 6″ and then routing the bundle of wires through “c” clamps wherever a bolt held body panels to the chassis. I got rid of tape and put the wires is corrugated split wire loom and then used tywraps to secure the loom to the chassis/body.
David B Dixon
SabineFebruary 16, 2017 at 6:23 pm #303018I would not recommend glassing in wires because some guy named Murphy will come for a visit and you have some reason to replace or adding another wire to the bundle
David B Dixon
SabineFebruary 16, 2017 at 8:29 pm #303023Hmm. Good thought. Murphy does seem to stick his neck where it doesn’t belong.
"If one thing matters, everything matters" - from the book The ShackFebruary 16, 2017 at 8:50 pm #303024I’ve not heard of anyone having a problem with the taillight wiring this way. A split loom taped with electrical tape should be fine. My car just has the tape. The tire is way ahead of it. The tail light has a rubber cup behind it, in the fender well, that the wire passes through. Keeps out the gunk the tire throws up–so far, anyway.
February 17, 2017 at 2:34 pm #303036Allen, I promised pictures. Hope this helps.
Â
 Â
February 17, 2017 at 6:41 pm #303040Thanks for the photos Paul. They really helped me and I’m sure others will benefit from them.
"If one thing matters, everything matters" - from the book The ShackFebruary 17, 2017 at 6:57 pm #303042If you want a waterproof boot for over the lamp socket, the distributor end of a spark plug wire will fit over it.
"Drive Happy"February 17, 2017 at 8:50 pm #303045Thanks Bill. My kit came with the waterproof boots.
