Home › Forums › MGTD Kit Cars › VW Based Kits › vw tins
- This topic has 26 replies, 7 voices, and was last updated 13 years, 5 months ago by
Mike.
February 18, 2012 at 8:30 am #233992
I’ve looked at alot of vw engines pictures the bottom tin is often missing.Mine doesn’t have it.Should i be worried about this.Any imput woud be appreciated.
FrankieD 2012-02-24 10:47:47 February 18, 2012 at 8:41 am #249280Better to have. You want to keep exhaust heat from recycling through your carbs.
February 18, 2012 at 8:41 am #249281Do you mean the two piece tin that goes between the engine case and the heater boxes? If so, I think that this one causes the fan forced cooling air to wrap around the bottom of the cylinders and the push rod tubes and prevents hot spots on the bottom of them as well as protecting the push rod tubes. Best advice seems to be: have all the tin in place.
February 18, 2012 at 11:57 am #249282If i need them where do i find them .Saw some on e bay awhile back. Jc whitney? does one size fit all? My engine is supposed to be 1600cc.
February 18, 2012 at 1:05 pm #249283I think your best bet is to go to some shop that has a lot of old VW junk engines in the back yard.
February 19, 2012 at 6:44 pm #249284I’ll go along with replacing the tin that was taken out of my London Roadster last summer. That was an ill-advised move. But I’m having trouble believing that thin metal plates will block heat significantly, knowing how uninsulated metal can transfer heat so easily. I hear the reasoning, but I am still skeptical.
February 20, 2012 at 5:30 pm #249285It has to do with separating the airflow from the hot areas at the bottom of the engine and the cooler air coming into the fan intake.
February 20, 2012 at 7:29 pm #249286Guys, don’t debate this. The question was settled by VW-knuckleheads generations ago. Install all your stock tins. They work.
Find them on the Samba. Last I checked there were 81 pages of classified ads for “tins.” What you need is likely in there.
February 23, 2012 at 11:27 am #249287I’m working with my mechanic who is rebuilding my engine and he will be custom fabricating some metal sheeting to go between the muffler and the engine to keep heat out.
February 23, 2012 at 11:45 am #249288“Cool!”
Greg, I realize that you live in NY and probably wonder why this is important. I lived there (NY) long enough to know that the asphalt roads get super hot in the summer and that reflects right up onto the engine. Cheap insurance. February 23, 2012 at 12:13 pm #249289“Quote: It has to do with separating the airflow from the hot areas at the bottom of the engine and the cooler air coming into the fan intake.”
I wish I had cooler air in the Phoenix summer! 115F might not be cool enough to run the VW engine in July or August. That sounds like the perfect excuse to head to the pine country or maybe San Diego. But I’d have to cross a big desert to get to San Diggy. With no A/C, that would be a brutal journey.February 23, 2012 at 1:08 pm #249290Quoting Royal in an earlier post:
Do you mean the two piece tin that goes between the engine case and the heater boxes? If so, I think that this one causes the fan forced cooling air to wrap around the bottom of the cylinders and the push rod tubes and prevents hot spots on the bottom of them as well as protecting the push rod tubes. Best advice seems to be: have all the tin in place.That is exactly what the bottom tin that runs just under the pushrod tubes is for. It truly does prevent those HOT spots from developing on the underside of the cylinders and the pushrod tubes. Back when the Doghouse cooler came out, VW spent a million plus dollars studying the airflow through the fan and around the engine and made a ton of improvements. All those seemingly useless pieces are really there for a reason. Cooling being the main one.newkitman2012-02-23 13:10:49
"If one thing matters, everything matters" - from the book The ShackFebruary 23, 2012 at 1:16 pm #249291I picked up a dog house housing for my current rebuild. I feel it is much better than the old one that was on there.
February 23, 2012 at 1:27 pm #249292MGLR didn’t you already have doghouse cooling? (I am having some difficulty finding old posts due to my advancing years.) If you did not, then you need to get a larger fan and an offset bracket for the oil cooler.
February 23, 2012 at 1:55 pm #249293The cooling shroud on the car when I bought it was a cheap, no frills version that we don’t think did a good job of distrbuting air. I bought the dog house because it has the internal fins (blades?) to direct air better. I’ll ask about the fan for it tonight when I go home.
I’m having an additional oil cooler installed to aid in handing our intense summer heat. It is coming together nicely, but I didn’t have my camera with me last night before the sun went down. Metal polished up, some chrome fittings, a paint job on the cooling housing and some fins. Should be quite a showpiece when it’s all done.February 23, 2012 at 7:03 pm #249294Today i took a picture of my engine to my vw man thats all he does rebuild engines.His main interest is volkswagon and porchse .He said to bring the car to him in the spring and he will check it out to see what it needs . Hard to tell from picture ,but it looks like alot of modificatons have been so mavbe it doesnt need bottom tin.
think springFebruary 23, 2012 at 11:45 pm #249295Those extra added-on external oil coolers don’t really accomplish anything, unless you have a fan blowing a significant amount of air over them. If it’s just sitting somewhere under a fender or in the engine compartment it probably won’t do anything other than slightly increasing your oil capacity.
The VW mechanic who rebuilt my engine removed the finned cooler that the PO had put on my car and installed a doghouse fan shroud with the improved VW oil cooler in it and that’s all you need. It gets in the mid 90’s where I live also and that setup works fine, and replace the tin.February 24, 2012 at 8:32 am #249296Right. Aftermarket, auxiliary oil coolers are for big builds only. And you better be an engineer, and lucky, if you want the thing to run reliably for more than a few 10s of Ks.
February 24, 2012 at 10:24 am #249297Are you saying I won’t get much lif out of my new bigger engine with the added oil cooler? Will it degrade or harm the engine in any way?
MGLondonRoadste2012-02-24 10:25:19February 24, 2012 at 10:29 am #249298It won’t add a thing to cooling except making you feel like you did something or it will increase you oil capacity slightly, like I said.
February 24, 2012 at 10:36 am #249299Edsnova post sound like a warning. I ‘d like to know more.
February 24, 2012 at 10:36 am #249300You’re not going big enough to make yours a grenade. The guys going way over 2 liters are pushing things too far, imho, which is really h, btw. A lot of them would shout me down for saying it.
1776, 1835, 1915 isn’t crazy big and should do fine in these cars, if they’re built carefully and not driven in competition. Stock doghouse cooler should work too.
You go much bigger and you’re outside the design basis of the stock cooling system, is all I’m saying. Once there, you need to be hyper-vigilant regarding all tolerances, materials, etc. etc. For me, the fun would drain out of it pretty fast.
I’d rather have a car I can drive all day at 70 mph for 10 years and never be able to do 90 than a car that can go 120 for 2 minutes and then never go 70 (or any other speed) again.
February 24, 2012 at 10:52 am #249301My cylinders got bored bigger, but not up to 92, so it will be closer to 1776 than 1835 I suppose. The extra cooler is to try compensating for the extreme heat we get in the summer. But without A/C, I most likely won’t be driving it too much anyway. Fall, winter and spring are my times to enjoy top down fun.
February 24, 2012 at 11:37 am #249302When I rebuild VW engines I always go up to 87mm pistons. And I let interested parties know that the mod is a straight “bolt on” mod and that drives the engine up to 1641cc giving it a little more kick from the red light. And you’re not changing the engine so much that the oil temps are significantly different. AND… the price for a 1600cc rebuild kit and a 1641cc rebuild kit is the same. Might as well go just a tab bigger for the price.
"If one thing matters, everything matters" - from the book The ShackFebruary 24, 2012 at 8:15 pm #249303The doghouse shroud should also have the newer offset oil cooler with it to work that much more effectively. It’s not only the shroud that should be replaced, it’s the newer version of the oil cooler also.
mrlmd2012-02-24 20:17:01 -
