Well let me start by saying….I was not ready to rewire the migi. It was the last thing I planned to do. I do not mess with electricity. However, the migi had an electrical fire while parked and battery plugged in, in the garage. Thankfully not to damage and no one was hurt. The master cylinder, I assume leaked oil onto an exposed wire connected to the master cylinder and created a flame. I was left with about 5 melted wires, a disfigured fuel pump(which was bad anyway) melted fuel filter, and a burned up master cylinder.
So needless to say a partial inspection of wires has been done. I am only working in the hood area. Once done I’ll move to the middle then to the back. I have found about 7 wires that literally go to nothing. Some are ground going from a bolt to the bumper with nothing electrical attached. It’s bizarre.
My main question is the wire housing with all the little screws a connectors on the fire wall–does ot matter what goes where on that portion only. And by that I mean…it’s a rats nest. I would like to place all lighting wires in a cluster group then move down. So basically relocate them on the screws. I’ve been making a cheat sheet as I go so that I know what wires are what.
But for instance I’ve labeled mine 1-16 top reading left to right. The passenger running light and what I assume is the rear tail light were on the same screw on down the line. I want to put just the front running light at top screw 2 and on its own screw separate from the sharing wire.
